Results 1 to 12 of 12
Thread: CYA Reading: DOT doesn't disappear
    Apr 2013
    Toronto, Ont. Canada
    35
    Hey, recently purchased the Taylor K-2006 Complete (FAS-DPD Chlorine Test Kit).
    Have tested my pool twice and I'm struggling w/ the CYA test. Specifically, the black dot never disappears.
    As instructed, I fill the CYA dispensing bottle to the 7 mL mark w/ pool water and than add R-0013 to the 14 mL mark and mix for 30 seconds. The "mix" is pretty clear (is the R-0013 not working?) and as a result, the black dot, when I test, is always present.
    FC = 0.5 ppm
    CC = 1.0 ppm
    pH = 7.8
    CH = 110 ppm
    TA = 80 ppm
    Thanks
    26k gal, IG Vinyl, 3/4 HP Pentair Whisperflo, Hayward S310T2 Sand Filter, Polaris 280 Cleaner, SWG
    Richmond Hill, Ontario, Canada
    May 2013
    South Jersey
    25
    Re: CYA Reading: DOT doesn't disappear
    Cya level is probably close to zero
    25000 Gallon Pentair Intellichlor SWG Gunnite Pool with Heyward DE Filter/Pump
    Test Kit - Taylor K 2006
    May 2013
    North East Ohio
    959
    Yep agree with the above, so did you add any chemical to bring up the CYA, etc...or is this a new fill.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Apr 2013
    35
    I have not added anything. It is a new fill. Assuming this explains the low FC level as well to certain extent?
    What's the best product to add? Thx for quick replies!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    You need to read pool school.
    Bleach and stabilizer are what you need to add.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Apr 2013
    35
    Thanks. Have been going through it.
    Stabilizer needs to be bought from pool store? I.e. there is nothing similar at Walmart type places?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Quote Originally Posted by hallidina
    Walmart sells it. So do a lot of hardware stores, especially this time of year. Grocery stores won't. Look for something in the 95% or better range. It's called stabilizer
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Walmart carries "HTH Stabilizer and Conditioner".
    Jun 2013
    Green Bay, WI
    72
    Quote Originally Posted by linen
    I just bought some yesterday. My walmart wanted almost $16 for a 15oz (roughly) just while our Menards (similar to home depot) had 25oz of a different brand stabilizer conditioner with identical numbers for $7
    So shop around!
    Doughboy 24' x 48" (AG), AQUA Tools Cartridge Filter, Frog System
    2004 Sundance Cameo SPA
    Jun 2011
    Long Beach, CA
    2,781
    My local pool store sold me a bulk pack of 5 lbs for $17. Some stores are better than others.
    I saw the HTH on walmart's website, $15 for 15oz! Bought some at Farm and Home supply, it was far cheaper, $6 for 1.5 lbs. The only thing I didn't like is that it said 100% cyanuric acid, instead of the actual ingredients/percentage.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    22,548
    100% Cyanuric Acid is the actual ingredient. Unlike other things, it can be 100% cyanuric acid.
