Thread: Summer Escapes 1000gph pump failure and replacement
    Had a feeling that pump looked a little cheesy! No big surprise that it failed after a month of hard running...
    Ordered an Intex 14in Sand Filter/Pump, and an adapter to hook up the intake hose to the S.E. thru-wall skimmer. Looks like it flows 1650gph. I like the S.E. skimmer, works well, and I like the second skimmer that the Intex pump has so I'm double protected from trash. I figure some pantyhose on the second skimmer and I'm set.
    Now, to keep the water sparkling until the goodies get here... Wish me luck!
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    Re: Summer Escapes 1000gph pump failure and replacement
    Good Luck!!!
    26k IG Vinyl, 2 HP single speed,24" Tagelus Sand, 1.5" pipe, 1 Main, 1 Skimmer, 2 jets, pool built 1983, new vinyl 2014, 36'x18', Deep End 8', The PoolCleaner 4X Suction.
    Pool Math #__# Pool School #__# Best Android App "Pool Pal" Track Your Levels!
    Jul 2009
    S. California
    157
    Cool. The Intex 1650 sand filter/pump is a pretty good combo and is working well on my 18 footer. With an eyeball return the pool circulates well. It actually pushes me in slow circles when I float in the pool
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    I decided to check out the cause of failure. Took apart the GFCI plug, water inside. So much for the weatherproofing!
    Put a standard plug on and the pump fired up. This is good, now I can keep up with filtration and water flow while I wait for the new pump/filter. Or course, pump off when swimming!
    Just completed the 1600 Sand Filter Pump install. It has been a few days since the last vacuum, and already the debris at the bottom of the pool has gathered in the center! Great flow! I used an adapter to allow the thru-wall skimmer that came with the pool, and used a hose adapter that came with the pump kit to make the attachment to the hose.
    I am not thrilled with that hose adapter connection. It is a compression fitting, and seems to be a fragile connection due to the weight of the plunger valve, hose and the water it contains.
    I have used some zip-ties to help support the weight at the bottom of the skimmer, as well as at the pump outlet. I will look for a better connection to the skimmer {or tips on finding one!}
