Results 1 to 15 of 15
Thread: New Pool Owner Switching From Pristine Blue to Chlorine
    Jul 2013
    San Antonio, Texas
    7
    Hello,
    I have purchased a pool about 2 months ago and got talked into using Pristine Blue. Since I cannot seem to get my pool looking clear I started to do some research and found alot of negative issues with Pristine Blue.
    My question is do I need to drain my pool if to switch from Pristine Blue to Chlorine? I really dont want to but if thats the easiest then I will. Also will i have to change out sand on the filter? If I dont drain my pool what steps will I need to take to switch over?
    Victor A.
    14,645 Gallons
    Sand Filter 19" 1hp
    Above Ground Pool vinyl
    Re: New Pool Owner Switching From Pristine Blue to Chlorine
    Welcome to TFP!
    The first step is to get your copper level measured. That will tell you how much water you need to replace, if any. You want the copper level below 0.3. Since the pool is fairly new it might not be much work to get it down to there.
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Making the switch is no big deal really. Keep with Jason's advice and get your Cu level measured. I would also suggest reading Pool School and getting yourself a high quality test kit such as the TF-100 from tftestkits.net or a Taylor K-2006.
    Jul 2013
    San Antonio, Texas
    7
    Thank you for your prompt response.
    Using my mini test kit my copper level is reading 0.5, hopefully thats not too high?
    I reviewed your reccomendations on the test kit and I will be ordering one.
    Victor A.
    14,645 Gallons
    Sand Filter 19" 1hp
    38,284
    As Jason said, you want it below 0.3 ... so likely a 50% water change might be a good place to start.
    Jul 2013
    San Antonio, Texas
    7
    Thank you. I will begin to drain about 50% of pool tomorrow and refill. It will take me about two days to refill because of low water pressure. Once my test kit comes in i will post the new copper levels. Should I respond with the results to this thread or start a new one?
    Victor A.
    14,645 Gallons
    Sand Filter 19" 1hp
    38,284
    Just keep everything here ... so we know where you started from.
    Jul 2013
    San Antonio, Texas
    7
    OK. Hope you all had a great 4th of July.
    I finally refilled my pool after draining it halfway. I tested the copper and it is at 0.3. What should be the next step? What it be easier utilizing the BBB method or just using the chlorine tablets i bought from Walmart along with all the other supplies.
    Victor A.
    14,645 Gallons
    Sand Filter 19" 1hp
    Aug 2010
    Dallas, TX
    4,052
    Can you post a full set of test results please?
    Jul 2013
    San Antonio, Texas
    7
    CL/BR = .5
    PH = 6.8
    Alka = 130
    Hard = 150
    Victor A.
    14,645 Gallons
    Sand Filter 19" 1hp
    Aug 2010
    Dallas, TX
    4,052
    To know whether you can use tabs, I'll need your CYA/Stabilizer numbers.
    But, first thing you need to do is get some chlorine in there. And your pH is low...
    Jul 2013
    San Antonio, Texas
    7
    Is it possible to not have any CYA because on the test it doesnt show any?
    Victor A.
    14,645 Gallons
    Sand Filter 19" 1hp
    Aug 2010
    Dallas, TX
    4,052
    That is possible, I would want to be sure it was tested for though.
    Jun 2012
    Howell, NJ
    977
    What kind of test kit do you have? If not one of the recommended test kits (link in my signature) you should get one of them.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jul 2013
    San Antonio, Texas
    7
    I have a Walmart 6 way test kit from HTH. I have just ordered the TF100.
    Victor A.
    14,645 Gallons
    Sand Filter 19" 1hp
