Thread: Baja too deep worried about bubbler
    My sundeck is 12 inches deep. It was not supposed to be so deep no can live with the depth but am worried the bubblers will not break the surface. Pool builder has offered to add steel and concrete on top but I am concerned. Any other suggestions/ ideas on how to make the bubblers work?
    30k Gallon in-ground, Vinyl, Loop-Loc cover, Hayward Super Pump, Hayward s-200 sand filter, Dolphin supreme m5, TF100 Test Kit, Speed Stir
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Baja too deep worried about bubbler
    I've never seen bubblers installed, could the end of the bubbler not be extended up to the new surface the pool builder forms?
    Could they chip away at the material around the bubbler to extend the pipe up so the bubbler's perform as intended?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    22,549
    Have you actually seen them not work yet?
    What type nozzles do they have on them?
    Killer95Stang's Avatar
    Sunny SoCal
    591
    My baja step was recently built at 12" deep with two bubblers. With no nozzles installed (just female threaded returns), the returning water breaks the surface approximately 1-2". That is with half the water being diverted to a rock water fall. With all the water being sent to the bubblers, it is higher and more noticeable. I've been told I can install telescoping nozzles if I want the water to shoot up higher above the waters surface, but I haven't gotten around to ordering them. I also figure I can just install a couple eyeball type nozzles in my threaded bubbler returns, to create a little more velocity to get the water higher up.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
