Thread: Intex Movement
    Intex Movement
    I can't seem to find an answer to this one... How much should the frame on my Intex move? I have two older girls who "dive" and jump around in the pool the entire time they're in there and the frame is in constant motion; creaking and swaying. We've only had it up for a few weeks, maybe a month, and it's on a concrete pad, so it's as level as it can be. I didn't expect it to move this much, so I just wanted to check that it's "normal" and not unsafe. The legs were level from front to back when I first set it up, but aren't anymore (I think they moved out when it was filled with water). Thanks!
    15 ft x 42 in Intex Easy Set Pool on a 20 ft x 20 ft Concrete Pad
    22,553
    Re: Intex Movement
    Those pools move a whole lot. I wouldn't worry about it too much.
    Jun 2013
    Ohio
    53
    Re: Intex Movement
    I concur. Constant motion.
    Intex Ultra Frame 18x48; Intex 56671EG 2,650-Gallon Sand Filter Pump; Intex Krystal Clear Saltwater System 15,000 Gallon
    Re: Intex Movement
    Awesome! Thank you!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Intex Movement
    Yes, that is completely normal. You will have to watch the legs, and move them back into proper placement. Using several "tie-down" ratchet straps wrapped around the bottom of the legs will help keep them in place.
    That's why I did a partial bury on mine.
    The top of the dirt is about even with the wide band that goes around the pool.
    We had a friend over with her daughter swimming today. Girl likes how clean and clear the pool is, and loves to jump off the platform at the top of the ladder. Pool just barely moved with all the water splashing around.
    Jul 2009
    S. California
    157
    Re: Intex Movement
    Yup, my kids have that thing dancing all the time.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
