Results 1 to 8 of 8
Thread: 5 year old just had a diarrhea accident in the pool
    May 2012
    Elk Grove, CA
    60
    From searching the forums here it looks like close the pool and super-chlorinate. How long should I wait before allowing people back in the pool?
    Chemistry was good when the accident happened.
    16k gal IG pool with SWG and DiamondBrite finish
    Pentair Intelliflo pump with 520 sq ft cartridge filter
    Aug 2010
    Dallas, TX
    4,052
    Re: 5 year old just had a diarrhea accident in the pool
    My opinion is that you need to be able to pass the OCLT.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Try the search using "fecal accident." There's a bunch there.
    May 2012
    Elk Grove, CA
    60
    My search for "code brown" wasn't very effective.
    Feb 2008
    Denton, TX
    5,061
    Just shock the pool. Keep it at shock level for 3 or 4 days while running the filter 24/7. You should be okay. This is not an uncommon problem.
    Casey's Avatar
    SW PA
    10,448
    Quote Originally Posted by cheezedawg
    OMG!
    That made me laugh!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2012
    Elk Grove, CA
    60
    Thanks all
