Results 1 to 12 of 12
Thread: Gatorade yellow algae growing on my pool sides?
    May 2013
    Fort Lauderdale, FL
    423
    I'm only 2 weeks into pool ownership. Been testing with my TF-100 daily. FC is hovering around 3-5, Ph 7.2, TA 110, and CYA was 0, but after 1lb of stabilizer, just checked in at 30. I'm getting lime yellow/green growth in the corners of my sitting area and steps and it's building on the sides and on some of the water returns. I just brushed the pool a few days ago. Do I need to shock? Scrub more? First time dealing with algae on the gunite. Water looks great though.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Feb 2008
    Denton, TX
    5,061
    Re: Gatorade yellow algae growing on my pool sides?
    Shock your pool.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Pool calculator tells me you need 385 oz of 8.25 bleach to get to the PoolSchool recommended 17FC.
    Pour those in tonight and see where you are tomorrow morning.
    -- Guy --
    30,421
    You have mustard algae. Start the shock process and then BRUSH those walls and floors often, stirring up the algae and exposing it to the increased chlorine in your pool.
    May 2013
    Fort Lauderdale, FL
    423
    Bummer. I'm having a 4th July pool party. Do I have time to shock now? Can I scrub it and get past the party then shock? Is it dangerous to swim in now?
    With cya of 30, pool calc shows 205 oz of 8.25 bleach to go from 4 to 12.....
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Is the water clear? I would say as long as your FC is below shock for your CYA, you are safe to swim. I would make your best effort each night but let it drift down for the party. But... after the party, get your FC back to shock levels. I would even say to have your chlorine measured and ready to pour so you can enjoy your party knowing you are ready ... for after that party. If you have mustard algae, the FC levels required are even higher.
    Just my two cents.
    -- Guy --
    May 2013
    Fort Lauderdale, FL
    423
    Yes it's clear. If hate to dump 2 gallons of bleach in right before kids will swim. I can put it in tonight and let FC drop for the 4th...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by zimm
    You'll be dumping bleach in again before the fourth. I'd get to work with the brush and raise that FC up and repeat it again and again as often as you can before the party. There's a chance it will be cleared up by then. You still have a couple days.
    May 2013
    Fort Lauderdale, FL
    423
    Cool. Just dumped two Costco 120-somethings of 8.25 and fired up the pump for the night. Will
    Check in the AM.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Is it looking any better today?
    -- Guy --
    In the summer the pools I've seen can get green algae in the corners/steps if the pump isn't running enough and the FC level drops corresponding with a huge rainfall. Did you recently get a big rain?
    15000 Gal Pool + Spa - Twin 2hp Pentair Pumps - DE Filter - 400kbtu Heater - Jandy wireless control system with freeze out - Polaris 3900 pressure side cleaner
    May 2013
    Fort Lauderdale, FL
    423
    Alright, the pool is fixed. Looked great the next morning. I zapped a few remaining spots with a brush and all looks good. TC level peaked at 15 with 2 large bottles of Clorox. CC was .5-1.0. Haven't done the DPD test today, but yesterday the yellow test off the scale so looking pretty good. Been running the pump 24/7, but now dropped it to 12 hours a day.
