Results 1 to 14 of 14
Thread: Wall Whale or Wall Whale XL?
    Jun 2013
    Philadelphia, PA
    143
    See lots of good comments on the Wall Whale - definitely think that's the direction to go. Then I saw the wall whale XL? Some people are saying it's really difficult to use on the bottom no matter how they adjust the fin and/or angle.
    Any thoughts? Anyone moved from the plain Wall Whale to the XL and been happy or wished to go back?
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    38,237
    Re: Wall Whale or Wall Whale XL?
    Depends on how quickly you want to make your arms ripped
    I can only imagine that the XL is pretty hard to push ... I have the original and do not have the fin all the way up.
    Jun 2013
    Philadelphia, PA
    143
    Jason -
    Looking online, I'm seeing the "original" with the larger tail (Also seen on the XL) and a smaller tail. Which one do you have? I'm thinking it's not the size of the brush with the XL that's the issue, but maybe the larger fin?
    TFT 100
    38,237
    Those pix look the same to me. Mine is not that big of a brush I don't think. The work comes from the size of the tail.
    Jun 2013
    Philadelphia, PA
    143
    The tails themselves are different - the bottom tail is probably twice as big as the top tail.
    TFT 100
    I really really like the larger brush on the XL, but the larger tail on the XL was troublesome enough when brushing the bottom that I have given up on the Wall Whale and gone to a standard brush.
    Jul 2013
    2
    Hello all, this is Greg, the inventor of the Wall Whale. A few comments which may clear some confusion. The tail we use is the same on all Wall Whales - 18", XL, 24" and 36".
    All of the versions of the Wall Whale can be hard to push on the floor because you have gravity and the tail working to your advantage. I found my natural way of brushing the floor was to hold the pole javelin style over my shoulder and it is hard to push. When held at waist level it is much easier to push. Also, the tail still exerts force even if the adjustor bracket is removed and this can make it even easier to use on the floors.
    I appreciate all the comments, good and bad. Feel free to call or write if you ever have questions.
    First time on this forum so apologies in advance if this is a breach of protocol but here's my info.
    gblackwell @ wallwhale.com
    817-266-7447
    Greg
    1600 gal AG Oval
    18x34
    1 1/2 HP hay 4 lb de 38 GPM
    Roover vac.
    pool owner 19 years
    Jun 2013
    Philadelphia, PA
    143
    Greg,
    Thanks, I appreciate the info. I assume the tail was redesigned at some point? As you can see in my photos above, I've definitely seen two different types of tails.
    ANYWAY, I just picked up the XL today, as that's all the local store had. Figured I'd try it from a local place, JUST in case. I'll be sure to stop back and post my results.
    TFT 100
    Jul 2013
    2
    The tail is the same as far as size and overall geometry. For the the XL we have removed the two highest settings for the adjustor as these setting put the tail past 45 degrees and creates drag instead of downward pressure.
    Greg
    1600 gal AG Oval
    18x34
    Roover vac.
    pool owner 19 years
    Jul 2013
    Florida
    20
    Quote Originally Posted by TroubleFreePat
    i looked up reviews on Amazon (to see what the product was) and found an owner comment about the differences as follows
    "I have both size wall whales, this one is great, the XL is a cheap plastic piece of junk at pool pole fitting and brush attachment."
    another reviewer commented on how the regular version gets into corners better than the XL
    *edit*
    i didn't read low enough to see you already bought it.. so you can clarify on the things i mentioned if they really are a problem.
    Intex 18' x 48" above ground
    Intex 2650gph sand filter
    Intex SWG/ Ozone generator
    Mar 2015
    CA
    2
    Quote Originally Posted by TroubleFreePat View Post
    Greg,
    I did not see the follow-up post on the XL. As this is a 2 year old thread, maybe we'll get "long-term test" review?
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    A bit late, but I wanted to weigh in.
    I had the original Wall Whale and liked it. As it seemed like a 1st generation product, it was a standard brush with the tail screwed down into it. I loved it, but eventually the plastic part of the brush all came apart and it was gone -- probably lasted 2 years.
    Then I say the XL and it seemed to have these problem addressed as it was all one assembly and had no "bolt on fin" but rather it was all integrated. I've had the now for almost 4 years and it is just now starting to show signed of giving up (I do not expect these to last forever -- this has lasted just fine). The plastic part that inserts into the pole is showing fatigue (white) marks as there is quite a bit of bending forces exerted in this area when used.
    As Greg stated above, when brushing the bottom, just swing the pole to as low an angle as possible and it works a lot better. It's not gravity that is hurting you, but rather that you are pushing at quite an angle to the floor (instead of relatively parallel to the wall when you are brushing the walls). There is a tough part just at the bottom of the wall where you are pushing down (cannot swing pole down as the wall is in the wall) but trying to make it move horizontally.
    Nothing is perfect, but I love the XL and would highly recommend it.
    If I could make any recommendations to Greg, it would be to wrap the brush bristles up and around the ends a bit so that when brushing around steps, etc it would brush up in the corners.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    38,237
    But .... With the original, I was able to take the fin off when the nylon brush fell apart and put it on a new mixed nylon/stainless brush. Can't do that with the XL.
    JoyfulNoise's Avatar
    May 2015
    13,171
    I have the Original WW too (going on 2+ years now). From the looks of it, it seems the parent company decided to revamp the design to make the brush non-serviceable rather than make spare brushes and parts available. Sad. They could have made money selling "Wall Whale Certified" OEM replacement parts at a little bit of a markup over generic parts and kept a loyal customer base....
    Matt
