Thread: Help! I cant move the eye!
    Jun 2013
    Northeast Alabama
    10
    I really hope someone can help me. I have AG vinyl pool, approx 10 years old. I have had normal replacements, liner, a pump, etc. My problem is that I can no longer move my eyeball to change the jet of water. I am scared to put to much force on it, that I might break it. Any ideas? Thank you in advance!
    27 ft round AG
    Sand Filter
    Vinyl liner
    Jun 2013
    SpringHill FL
    415
    Re: Help! I cant move the eye!
    I typically use the handle of a small screwdriver (with the pump off) insert it into the eye and carefully move it around to my desired position. I only do this when they wont move with just the force of my fingers
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    I used a brass drift, since it fit snug in the eyeball. The extra 6" of leverage makes a world of difference. Even a wooden dowel will give you leverage.
    Jun 2013
    Northeast Alabama
    10
    Thanks so much for the info!!
    27 ft round AG
    Sand Filter
    Vinyl liner
