Thread: Filter Hoses
    Filter Hoses
    How often do they need replaced? It seems the high pressure hose, and how the one running to the pump have sprung leaks. BTW, duct tape is NOT a good temporary fix.......
    Christine
    18 X 54 Round-Wilbar-Sharkline Above Ground Tahitian
    Stainless steel access panel/ 1.5 hp pump
    Self Installed 6/09
    Crushed by Irene, and a 50ft oak 8/28/11
    Re installing 4/12 and up and running
    22,549
    Re: Filter Hoses
    I'd say every 2 to 4 years if they're out in the sun. They may last longer if they are protected.
    Re: Filter Hoses
    Ok. The hoses are disassembled and put away each season. 2008 they were new, and we reused them from the old pool that was destroyed by a storm. So I suppose it isn't that unusual to have to replace them after almost 6 years of use.
    They are leaking pretty bad too. I am worried that all the water is going to leak out of the skimmer before I can replace them...
    Self Installed 6/09
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Filter Hoses
    If they are leaking, replace them before they burst. I like the black ones with cuffs. The seem to last longer and they are easier to work with.
    The others ones I use when I cannot get the black ones
    I do not but from these vendors, I only used the photos as they were convenient.
    -- Guy --
    Re: Filter Hoses
    My Hillbilly fix until the hoses arrive.............
    Self Installed 6/09
