Thread: Results ? please advice
    Jul 2007
    Michigan,
    18
    Hi, here are my first results of the new season
    FC---2.5
    CC--0.5
    TC--3.0
    TA--400
    CYA-NIL
    PH--7.8
    What are the first steps to take to correct these results
    btw the water looks good just now after taking out a lot
    of **** as the result of leakage from winter cover
    Best Regards David
    14500 gl, oval, vinyl
    You want some CYA in the water. If you have an indoor pool then CYA around 20. Outdoors with a SWG then CYA between 60 and 80. Otherwise CYA between 30 and 50. It is probably best to add about 2/3rds of the amount you think you need at first. Give it a week to dissolve and then test again to see where you are.
    Your TA is very high. You are going to need to bring that down. See the lowering TA sticky.
    Because your TA is so high it is important to know your CH level.
    You should bring your PH down to 7.6 or lower and keep it at 7.6 or lower until you get the TA level down.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi D&B,
    Please list all your pool and equipment info in your signature. This will be a big help!
    Welcome to the forum
    You're done SLAMing when:
    The lower the pH, the better from the point of view of removing alkalinity. Ideally, you're going to want to keep it around 7.2 or so for a while with muriatic acid. This is still fine for swimming, but it will burn off TA. Keep checking it and as it moves up above that, drop it down. If you have fiberglass or gunnite, you can drop as low as 7.0 to burn off TA, but keep the vinyl pools at 7.2 or above.
    Guest
    actually, you can safely drop a gunite or fiberglass pool as low as 6.8 and a vinyl pool to 7.0 when you are lowering TA.
