Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: pool school swcg question
    May 2013
    39
    Hello All,
    I just read the guidelines on poolschool for swcgs and was interested to see the recommended TA figures at 60 to 80ppm. This appears to be a little lower than normally recommended for non-swcg pools. Can somebody please explain the reason for this?
    I have experience looking after a few swcg pools but wasnīt aware of the need for such a low TA.
    Thanks in advance
    38,268
    Re: pool school swcg question
    Sure.
    A SWG inherently drives the pH up due to conditions within the cell. By lowering the TA, this should help to stabilize the pH so it will not rise as quickly.
    One could easily make the same argument for pools with spillovers or water features that are run a lot.
    Apr 2013
    Chandler, AZ
    123
    I was curious about that, too, thanks for the info.
    Now a related question. What happens if the TA gets below that range? I am always having to add acid to lower my pH and my TA is now within range. I expect that it will be low at some point due to always adding acid. What's the concern with a low TA?
    Bryan
    My Pool Build
    IG 16,148 gal (pool+spa), Mediterranean Pebble Plus, Noce Travertine Coping and Deck, Hayward ProLogic 8 with AquaPod, Hayward EcoStar VS Pump, Hayward 60 sqft DE filter, Hayward T15 SWCG, Paramount Clear O3 Ozone, Hayward 400k BTU NG Heater
    May 2013
    39
    Sure.
    Thanks for the reply. I checked a salt water pool today and the readings were 95 TA and 7.5pH. Normally I wouldnīt add acid yet, but would the experts on here be lowering the TA with those readings?
    bacevedo, please ask questions in your own topic.
    38,268
    Ideally you would want the TA a little lower if you are seeing a pH rise. It does not make a huge difference if you lower the pH now or wait for it to rise some more.
    May 2013
    39
    OK think I understand. I donīt have a particular problem with pH rise, although as you said it always rises with a swcg. However, if I was to lower the TA to 80 it would slow down the process of increasing pH and presumably lessen the quantity of acid I use?
    Many thanks for your replies jblizzle. If you were closer Iīd buy you a beer
    Aug 2010
    Dallas, TX
    4,052
    I'd go more, down to the 60-70 range. (actually, I did, but I recommend the same for you )
    May 2013
    39
    Quote Originally Posted by RobbieH
    If I find a calcium problem on a pool surface I usually decrease TA to just below 50ppm to clear the build up of calcium, then increase TA again once itīs disappeared.
    Iīm not disbelieving you people, and I understand that swcg pool chemistry is different, but the 60 figure sounds awfully close to the 50 Iīve always used to clear calcium. I always understood that if you leave TA below 50 that eventually youīd lose the grouting between the tiles.
    I guess you are recommending 60 though and not 50 but Íīll have to do my calculations correctly to make sure I donīt overdo the acid
    Aug 2010
    Dallas, TX
    4,052
    You can go to 70 and see what that does for you first.
    May 2013
    39
    will do robbie. ps what does built in 1957 refer to?
    Aug 2010
    Dallas, TX
    4,052
    The year my pool was built.
    May 2013
    39
    wow, that must have been built well! guess you need a pool over there with this heatwave youīre experiencing.
    Aug 2010
    Dallas, TX
    4,052
    It's a cool wave this week. But that'll change again next week, back to triple digits.
    May 2013
    39
    thatīs in great condition. you certainly build well on your side of the pond!
    our gunite pool which is 10 years old sunk by half an inch last year. luckily it hasnīt cracked, yet.
    38,268
    Quote Originally Posted by costablanca blue
    You have to keep the other parameters in mind ... specifically the CSI. So if you maintain a lower TA, you may need to increase the CH some or just keep the pH a little higher so the CSI does not get too negative which could eventually cause the grout problems you mention.
    May 2013
    39
    understood thanks jblizzle. just noticed your tag - very sad about those poor firemen in your part of the world. those wild fires sounded horrendous.
    38,268
    You know, I had not even realized there were fires going on when I heard about the firemen ... still have not really heard what happened. I guess I do not pay enough attention to the news.
    Am I reading this correct and you are saying that my water feature affects my TA and PH in a negative way? I have my water features on all the time and I am fighting PH and TA levels a bunch.
    15K gal gunite, Jandy Aqualink RS, Aquapure 1400 SWG, Jandy main filter pump, Century Pool & Spa 3.0hp cleaner boost pump, Polaris 360 Vac-Sweep, Jandy Large Cartridge Filter. K-2006 Test Kit
  20. Back To Top    #20
    Jun 2011
    Long Beach, CA
    2,781
    Water features that aerate the water will make the pH rise. By keeping the TA lower, 60-80 range, it will help to keep the pH from rising as fast.
