Thread: Green pool upon return from 4day vacation
    Sep 2009
    Alabama
    22
    Power off so pump didn't run for 4 days. Green murky water but can see bottom looks like jolly rancher green. I'M following guidelines posted here just wondering how long it might take and if any other suggestions?
    FC up to16 but drops 2-3 each hour so far. We are brushing each hour.
    FCC 16
    Cc .5
    Ph 8.2 too high?
    Alk 90
    Cya 40
    Pool specs in signature,
    Thanks for your help!!
    13,500 gal AG, cartridge filter, 2 sp Waterway pump. TF-100 Test Kit (Love it !!) Repeating Pool School.....learn something new everyday !
    Casey's Avatar
    SW PA
    10,444
    Re: Green pool upon return from 4day vacation
    Disregard pH levels while completing the shock process. Keep FC levels up and don't let up until you can pass the OCLT.
    Sep 2009
    Alabama
    22
    Will do, thanks!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Since you're on top of it, I'd guess just a few days total. Your CYA is low enough that you could have put a floater full of pucks in there before you left.
    Well, you'll know for next time....
    Sep 2009
    Alabama
    22
    Pool is back in the blue...well blue liner that we can see now and almost sparkling clear water we've come to love and expect with the BBB system !! (held fc last night with .5 cc, expect to have process complete overnight tonight (keeping fingers crossed, want it ALL gone!)
    Again, I'm trilled to have found this site and thanks for the note about floater, will keep that in mind for next time!
    Question, is CYA too low at 40? We've had to add water several times so far this summer, very hot and may have a slow leak somewhere.
    Hope you guys have a safe and happy 4th!!
    Debbie
    Isaac-1's Avatar
    SW Louisiana
    6,711
    40 is ok, depending on amount of sunlight you get and what part of the state your in, if you are in the south part of the state and get a lot of sun you might want to raise they CYA to 50
