What kind of in-ground cleaner system is this?
Jul 1, 2013
3
Las Vegas
Hello and thank you thank you this site is amazing!
I am needing to replace some pop-up heads in my pool and don't know the manufacturer.
Before I go out and start spending money does anyone know who made this?
Replies greatly appreciated...
-newb(pool-owner/forum-poster)
It's a Master Pools Turbo Clean system, my pool had the same one. The heads used to spray filtered water in "zones" to push/flush dirt/debris to main drain (mine has 5 zones, 2 outflows per zone in pool and 1 in spa) and the original TC heads were 1" above the surface spraying water 360 deg--see image, with newer A&A heads pop up and rotate 360. A&A manufacturing offers a retrofit head kit: Item: 555807 adapter/heads (555807 Turbo Clean Adapter package- White- $49.40/each). The space ship thing can be replaced also with A&A stuff!
It does not look like a Master pools valve.
It looks like an A & A Manufacturing 5 Port Top Feed Valve. The A & A Low Profile Actuator Valve looks similar to the Master pools valve. A & A might make the Master Pools valve, but I don't know.
