Results 1 to 10 of 10
Thread: What kind of in-ground cleaner system is this?
    Jul 2013
    Las Vegas
    3
    Hello and thank you thank you this site is amazing!
    I am needing to replace some pop-up heads in my pool and don't know the manufacturer.
    Before I go out and start spending money does anyone know who made this?
    Replies greatly appreciated...
    -newb(pool-owner/forum-poster)
    22,551
    Re: What kind of in-ground cleaner system is this?
    I don't recognize it. Is there a spaceship looking thing near the equipment pad?
    Jul 2013
    Las Vegas
    3
    so...yes to the spaceship looking thing?
    22,551
    That's an infloor cleaning system, but I don't recognize it. Maybe someone will come along that does. Are there any markings on it?
    Jul 2013
    Las Vegas
    3
    It's been out in the sun long enough that any labels are unreadable.
    thanks though
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    I don't know what kind of popup's those are but the spaceship thing looks like an A & A Mfg. http://aamfg.com
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I've never seen a popup like that...sorry!
    Wildcat's Avatar
    Jun 2013
    309
    The unit looks like my turbo clean though your popups are different
    http://www.infloorpoolparts.com/quickcl ... 12112.html
    This looks like it too. I was able to get a replacement top and gear set locally in Tucson when it stopped working. I have the original brochure somewhere and can find it if it will help you
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Feb 2016
    Palm Springs, CA
    1
    It's a Master Pools Turbo Clean system, my pool had the same one. The heads used to spray filtered water in "zones" to push/flush dirt/debris to main drain (mine has 5 zones, 2 outflows per zone in pool and 1 in spa) and the original TC heads were 1" above the surface spraying water 360 deg--see image, with newer A&A heads pop up and rotate 360. A&A manufacturing offers a retrofit head kit: Item: 555807 adapter/heads (555807 Turbo Clean Adapter package- White- $49.40/each). The space ship thing can be replaced also with A&A stuff!
    Quote Originally Posted by Aquamojo View Post
    It does not look like a Master pools valve.
    It looks like an A & A Manufacturing 5 Port Top Feed Valve. The A & A Low Profile Actuator Valve looks similar to the Master pools valve. A & A might make the Master Pools valve, but I don't know.
    Support the site
