Results 1 to 7 of 7
Thread: pH Test Question
    Oct 2011
    Orlando, FL
    63
    pH Test Question
    Hi there, I don't know if I have a ghost in my water or what, but after more than a year of easy-peasy testing, I'm having trouble this year with the basic tests.
    I discovered that I am unable to do a proper CL test anymore. See here if you care chlorine-consumption-shocking-testing-maybe-not-insects-t63318-20.html This problem is still there - no two test are ever the same...
    Now, the pH test is acting weird. I'm not talking about that it's hard to read the color - I've figured that out by now. What happens is this. If I shake the bottle a few times, I read a certain pH, around 8 in this case. Shaking vigorously a few more times, it drops to a lower number, around 7.5. And I know you won't believe me, but shaking it vigorously a few more times, it drops even more, in this case to 7.2!!! No further shaking would change it any further.
    I mean, how many shakes is the right amount? I've always just shook it maybe 5-10 times and used that result. And it turns out another 5-10 it changes???
    Or what is your experience with haunted water?
    screened-in 10,500 gal IG gunite pool, DiamondBrite, 1.5 HP Hayward Super II Pump, Hayward Star-Clear Plus C1200 Cartridge Filter, Hayward Pool Vac Ultra, 6 solar panel heater.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: pH Test Question
    You vigorously shake the PH test?
    I just turn it upside down and right side up a few times......
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jul 2011
    St. Paul, MN
    244
    Very strange.
    It shouldn't matter how much you shake it.
    I would try giving the test vial a good cleaning.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Oct 2011
    Orlando, FL
    63
    Quote Originally Posted by harleysilo
    Right, that was my normal operating mode, as well. But then I'm noticing that shaking it up changes it, so naturally now I wonder: When is the 'right' amount of shaking to read the test!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Well I've never shaken it, since the instructions say Invert. However now i'm going to and see what happens, i should try the speedstir too!
    18'x43' Sport Pool
    30,403
    My impression is you are trying too hard to "fool" this test. After you add the five drops, you shake it well enough for the color to be uniform throughout the column and that's the end of the test.
    There is no point shaking it further so I have no idea if that will affect the test result or not. I usually get the column mixed well in about 1 second.
    Oct 2011
    Orlando, FL
    63
    Thanks. I wasn't trying to fool it on purpose, but just noticed that just a few extra shakes change the color significantly. It just doesn't seem that this would be normal ...
