Results 1 to 7 of 7
Thread: Just making sure I am perfect
    May 2013
    North East Ohio
    959
    I finally got everything all balanced (I think) and I wanted to publish what I have JUST to make sure I am not missing anything.
    FC - 5
    CC - 0
    pH - 7.5
    T.A - 90
    CH - 100 (have no calcium based fillers in fiberglass)
    CYA - 40
    My only gut is perhaps I should get the pH up a little, but I am waiting till the somewhat newly added last bit of CYA dissolves, etc.
    Any other thoughts - fire away!
    Oh, water is crystal clear !!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    30,403
    Re: Just making sure I am perfect
    Doesn't get much better than that. Leave your pH alone....it's just fine.
    May 2013
    North East Ohio
    959
    Cool, as always thanks!
    Butterfly's Avatar
    South Carolina
    10,045
    With 40 CYA, keep FC between 3 and 7, and never below 3. If you are at 5FC now, you may be too low later. I suggest you dose up to about 7 each evening and see where you end up.
    Your pH looks absolutely perfect and I'd leave it alone.
    We do recommend a higher CH of 220 to 320 for FG pools to help prevent cobalt spotting.
    Link to Pool School Recommended Levels:
    pool-school/recommended_levels
    Nice job overall
    You're done SLAMing when:
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Not sure about you being perfect.....but your pool water chemistry looks pretty darn good!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    North East Ohio
    959
    Quote Originally Posted by Butterfly
    Nice job overall
    Yeah, I've dropping 1.5PPM of FC while at 30 CYA, so thinking at 40 I still should be good....will test a bit to see if I get that consistency still.
    As for the CH, I am a little confused on the CH level...meaning look at this thread where I was told not to worry about it. Now I am not trying to pit one against the other, just trying to understand.
    http://www.troublefreepool.com/calci...ls-t61049.html
    May 2013
    North East Ohio
    959
    Quote Originally Posted by harleysilo
    Well, I think my wife would agree with you
    About me vs. the pool chemistry that is!
