Results 1 to 7 of 7
Thread: Custom Made Water Level
    Jun 2013
    Seguin TX
    192
    Greetings,
    A ran across a post a few days ago in this forum where someone had show the custom water level they had made using a couple of boards, some hose with colored water and some rulers mounted to the board to check the level around their pool foundation.
    If anyone can point me to this post it would be greatly appreciated, I want to make one of these things for when we pull down our pool at the end of the season to make sure our foundation is as close to level as possible,
    Thanks
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Casey's Avatar
    SW PA
    10,427
    Re: Custom Made Water Level
    Not sure which thread you are talking about but I posted a youtube vid to one because I'm going to do this too.
    anyone-use-a-water-level-to-install-their-pool-t61914.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Casey's Avatar
    SW PA
    10,427
    HA! I beat ya Richard!
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by Casey
    That's only because I was looking at harbor freight. I know I've seen kits that have the plastic tube with hose ends somewhere....
    EDIT: Found one on Amazon. http://www.amazon.com/Mayes-Level-10309 ... B00004YZP8
    Casey's Avatar
    SW PA
    10,427
    lol
    Jun 2013
    Seguin TX
    192
    Thanks Guys
