Results 1 to 10 of 10
Thread: Family guy
    Jun 2013
    SpringHill FL
    415
    Family guy
    Please do not hi-jack another member's thread.
    225ppm fc
    2.5ppm cc
    7.5 ph
    120 ppm alk
    130 ppm calcium
    40 ppm cya
    Anything look abnormal? My first test with fas dpd test kit
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Got my new test kit and unsure.....
    Quote Originally Posted by FamilyGuy
    225ppm fc
    2.5ppm cc
    7.5 ph
    120 ppm alk
    130 ppm calcium
    40 ppm cya
    I see a typo on the FC. And CC is too high. But keeping FC above 15 for a few days should eliminate the CC.
    Jun 2013
    SpringHill FL
    415
    I will retest and check my math but fairly certain its correct i may of super super clorinated my swamp. Good news is it is turning clear and i can see the bottom of the deep end for the first time this season
    Nathan
    Richard320's Avatar
    Jan 2010
    18,984
    225 ppm FC is WAY too high. I imagine you have a white liner now, since you've bleached it. A very Peter Griffin thing to do, I might add.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Check these videos, and see if you are doing the same.
    http://www.youtube.com/user/tf100tes...e=results_main
    I'm betting you are forgetting the decimal point when multiplying for your FC.
    As Richard said, if your FC was really that high, you would at least have a bright white liner, that won't last much longer. How many 55 gallon drums of bleach did you add?
    Jun 2013
    SpringHill FL
    415
    Lol ok by your responses i apparently misread my test i put about 12 gallons of 3%clorine and 8 gallons of 8.25%
    Nathan
    Jun 2013
    SpringHill FL
    415
    As you guys already knew my fc multiplier was to blame my curent numbers are the same as above except
    Fc 28-30 ppm ( checked twice and got both numbers)
    Cc .5
    Nathan
    Sep 2009
    Greentown, IN
    914
    Whew.. Liner saved Glad you got that figured out. Now you'll be well on your way to a sparkling pool!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jun 2013
    SpringHill FL
    415
    Re: Family guy
    Yes gone from cloudy green unable to see low end to quasi crystal clear overnight
    I gotta say the wealth of info in the forums and the people who respond to the posts are amazing i cant thank all of you enough. I am sufficiently impressed by how little effort i think it will take to maintain the pool without the pool store ripping me off
    Nathan
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Family guy
    Just as an FYI, PH testing at FC level's above 10 is not accurate, so no need to keep testing it until your FC level drops.
    Welcome!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
