Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Overwhelmed by all these numbers....what do i need??
    Jun 2013
    Green Bay, WI
    72
    Just finished filling the pool (18'x48" Intex Ultra) yesterday and ran the test with my TF-100 kit.
    Ph 7.5
    TC 0
    TA 380
    CH- started turning purplish around 30 drops but wasn't seeing alot of difference when i stopped at 45 drops.
    CYA - filled the test tube and could still see the dot
    I want to do the BBB method as a FYI.
    So please tell me specifically what I need to do as this is becoming very overwhelming to me. I tried doing the pool calculator but i don't know what exactly i am reading. I need someone to babystep me through this
    Thanks
    Matt
    Doughboy 24' x 48" (AG), AQUA Tools Cartridge Filter, Frog System
    2004 Sundance Cameo SPA
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Overwhelmed by all these numbers....what do i need??
    You will need to add bleach/liquid chlorine & CYA.
    If you have some bleach (plain, unscented) on hand, add it now. Use the PoolCalculator.com to help you figure the dose. Add about 2PPM.
    Wallyworld, big box stores, pool stores, etc. sell CYA (a/k/a conditioner/stabilizer) . Ingredients should be close to 100% cyanuric acid.
    While there, pick up the bleach/liquid chlorine and some muriatic acid.
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Get the smallest CYA container they have. You should only need about 2 pounds.
    Jun 2013
    Green Bay, WI
    72
    Butterfly,
    Thanks for the post. Im getting confused at the pool calculator because it seems like it wants more inputs than I have to give. So I am not sure what i should all be entering/removing, etc.
    I plan to go to Wally world after work today so that's why i am trying to get my shopping list in order. I have an impatient 6 year old waiting to get in that pool.
    Butterfly's Avatar
    South Carolina
    10,045
    You should get some bleach/liquid chlorine in there now. 3 or 4 cups should do for today. Add it ASAP because you don't want to start any probs w/algae.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Start by imputing as much info as you have for the spots where i've put a red arrow in the picture below. If you don't have data, don't enter it. I'm assuming you don't have Salt or Borates data, that's fine, you should have the rest.
    Next, fill in the target levels you want to achieve in the spots where i've placed the green arrows in the picture below. Once you input number the calculator recalculates in the background instantly, you can also press the Calculate button near the top.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by willie1280
    Butterfly,
    Go to PoolCalculator.com and....
    First, add the pool gallons at the top.
    Now, drop down to FC: put a zero in the 'now' column and 2 in the 'target' column, then click 'calculate'.
    Hover mouse over the ounces and look up under the 'calculate' button and see ozs. translated to cups, quarts, gallons, pounds, etc.
    Now, drop down to CYA: put a zero in the 'now' colummn and 40 in the 'target' column, then click 'calculate'.
    Hover the mouse same as above for weights translated.
    Lemme know what you get for calcs. We'll help confirm doses with you.
    Forget about other stuff for now.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Did you fill with well water?
    If you check this out extended-test-kit-directions-t25081.html
    And look at the section for CH (scroll down), you'll see an explanation about why your CH test is acting funny.
    Specifically
    "The sample may turn purple during the test, or go to blue for a moment and then turn back to red/pink. This is called a "fading endpoint" and is caused by interference from metal ions. If this happens, do the test again, but this time add five drops of R-0012 before adding any R-0010 or R-0011L. Remember to count the initial five drops in the total.
    In extreme cases, a fading endpoint may occur even when adding five drops of R-0012 at the start. If that happens, mix pool water with an equal quantity of distilled water, test that, and then multiply the result by two."
    18'x43' Sport Pool
    Jun 2013
    Green Bay, WI
    72
    Quote Originally Posted by Butterfly
    Butterfly,
    It says 27oz (3 cups 3 oz) of 6% bleach and 36oz of stabilizer.
    Jun 2013
    Green Bay, WI
    72
    Quote Originally Posted by harleysilo
    Specifically
    Yes I did fill with well water and i think it's got quite a bit of iron in it.
    I simply went with the testing procedures that came with the kit, which i think only described a few. So i've printed off the link you sent me so that i can run all those test in the future.
    Additionally, the water is somewhat cloudy. I can see bottom but it's got a milky white color to it.
    Should I keep the kids outta the pool at this point yet or where am i at safety wise?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Those are just the extended test instructions, they are for the same tests you've done, just give more details in case you run into problems testing.
    What water someone is willing to swim in is such a personal decision. You drink the water so should be fine for swimming, i'd get some chlorine in there first, and start getting your CYA dissolved as well.
    18'x43' Sport Pool
    Jun 2013
    Green Bay, WI
    72
    Sodium Hypochlorite is the value i look at to determine the blech percentage correct?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Correct.
    18'x43' Sport Pool
    Jun 2013
    Green Bay, WI
    72
    The calculator said a little over 2lbs of stabilizer. Should i get (3) jugs of the 15oz HTH brand for $16ea or is there a more cost effective solution?
    Jun 2013
    Green Bay, WI
    72
    Menards has 1.75lb buckets made by Utikem for $6.29, so 2 buckets of that should be plenty. Is that brand sufficient?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Should be just fine.
    18'x43' Sport Pool
    Jun 2013
    Green Bay, WI
    72
    My wife any gawking neighbors are going to think im nuts putting a white powder into a sock and then tossing that in the pool
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    LOL, make sure you hang it near a return so water circulates around it, which will help it dissolve faster. You can also give the sock a couple squeezes now and then to speed it along the way. Now it would be funny if you had an old sock monkey you could use....
    18'x43' Sport Pool
    Jun 2013
    Green Bay, WI
    72
    Is there a certain amount of time I should wait to allow my kid into the pool after I do the bleach and CYA?
    Can I do the bleach and CYA simultaneously?
  20. Back To Top    #20
    Mar 2007
    San Rafael, CA USA
    12,082
    You can do the bleach and CYA simultaneously. You'd add the bleach over a different return than you are hanging the sock. Or if you have only one return, then remove the CYA sock, add the bleach, then put the CYA sock back.
    You can certainly have people in the pool an hour after you've added chemicals, though in pools with decent circulation it can be sooner than that. My own pool has very good circulation and after I add chlorine over one return in the deep end where I have a floor drain, I measure the FC rise throughout the pool within 10 minutes and after 20 minutes it's pretty much mixed. However, this depends a lot on the pool so saying 1 hour is safer in case your pool doesn't have great circulation. If you have only one return and one skimmer and no floor drain, the I suggest you lightly brush the pool in the area where you add the bleach just to help with bottom circulation/mixing.
