Thread: All Lights on - SWG Not producing Chlorine
    I'm working with a Goldline controller hooked up to a Jandy Auqarite RS system. I set the goldline generator to be remotely controlled by the Aquarite by emulating the Aquapure generator - (AL-5 setting). All lights are on, power, flow, generating... all green. When I put it in shock mode remotely, that light goes on too. I replaced the cell at the end of last season using a generic brand vs. the goldline (perhaps a mistake?). Despite setting the unit to 100%, when I test the chlorine coming directly out of the generator, it isn't reading anything. (pool being kept in balance using tabs and bleach to shock)... numbers below are current but it was at about 1.5 when I tested it. Even with a 2.1, shouldn't I expect the values coming out of the generator to be higher when it is set at 100%?
    Temp 80
    Saturation Idx -0.5
    TDS 4000
    CYA 50
    Total Chlorine: 2.1
    Free Chlorine 2.1
    PH: 7.4
    Total Alkalinity: 112
    Adj Tot Alk: 104
    Total Hardness: 103
    Minerals 3000
    Note 1: I just switched out the PCB of the Jandy to the aqualink IQ 900-RS. Everything appears to be working properly... when i boost the generator from a hand held device the settings on the Goldline controller change.
    Note 2: All of the diagnostic data from the goldline generator are within the specs recommended in this forum and the manual.
    35k Gunite, Aquarite SWG T-Cell 15, DE Filter
    Attached Spa, Water Leveler (from well / metals)
    Polaris 380, Jandy RS8 with Aqualink
    Cape Cod, Massachusetts
    Re: All Lights on - SWG Not producing Chlorine
    I should also add that it is a generic t-cell-15 for pools of around 40k gallons, the pool is 35k gallons, in ground, gunnite, 7 years old, DE filter
    22,553
    How are you testing the water? Those look like pool store results.
    The water right out of the return is only going to be a ppm or two higher than the bulk pool water.
    I test using strips, testing kit (Taylor something... at work now so can't check the model) and backing those up with results from the, yes you guessed it, pool store. All three seem to be in about the same place with respect to results. (although my kit doesn't give me hardness, salt level, etc).
    Ok... so I shouldn't see any noticeable difference in testing the water coming directly from the return. humm... any other way to validate that the cell is working properly? I did clean it a week ago (although there was no scaling on it so I don't think it really needed cleaning).
    22,553
    You can crack the downstream union on the cell a bit so it leaks and catch a sample there. It should be a few ppm higher than the bulk pool water. It won't be much but it should be enough to tell a difference.
    If you have one of the recommended kits they will test for hardness. Do you have the FAS-DPD test?
    Right now the sample is actually coming from the polaris vaccuum hose vs the return, which is also fed by the chlorine generator so it isn't being mixed with any of the pool water. I'll try as you suggest but not sure that it would be much different?
    One other thing I thought of is that the cell is only about 3 linear feet from the heater and also services the spa. The temp doesn't get above 102 but could the hot water somehow be burning out the cell?
