Results 1 to 10 of 10
Thread: Tricks for putting the lid on the pump basket back on?
    May 2013
    Toronto, Canada
    73
    I have a Pentair Dynamo pump. I removed the glass lid to clean out the strainer. Now I can' get it back on. It has to be rotated so that it fits into two groves. The problem is that the lid isn't flat enough for both sides to fit into the groves. I thought turning on the pump would suck the lid flat on so I could turn it but that didn't work. Can I hammer it in?
    Very frustrating. It looks like it should be easy but it Isn't!
    Any hints would be much appreciated.
    Philip
    Philip
    12.5x21.5x52" on-ground 29" below ground (6000 gallons water), .85 HP Hayward SP26115VSP , Hayward XStream 100 sq.ft. cartridge filter, Hayward AquaRite salt system, 160 sqft of Aquatherm solar panels on 12' high flat roof 25' away from pump, Goldline auto controller for solar, Heat Pump, May->October @77+ in Toronto, Pool Python.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Tricks for putting the lid on the pump basket back on?
    Are you sure the o-ring is completely in place?
    Try a little pool lube (plumbers lube, silicon based) on the o-ring. That could be holding the lid off just enough to cause what you describe.
    38,267
    If it is warped, you may need to buy a new lid.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    This may or may not help...i have the intex sandfilter...and when i tried to put the lid back on when I cleaned the basket i had one hard time....i had forgotten to close the return valve! I only closed the outlet valve...so water was coming backwards through the pump and making it hard for me to screw on properly
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    May 2013
    Toronto, Canada
    73
    Thanks for all the help. Putting some vegetable oil on the o-ring seemed to help. It finally went back on. Am getting a new pump this year so I hope I can get a different design.
    Philip
    Philip
    38,267
    Why would you use vegetable oil and not a gasket or pool lube? You always need to lube the o-ring to ensure a good seal.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    It's better than petroleum oil!
    38,267
    Quote Originally Posted by Richard320
    Valid point
    Casey's Avatar
    SW PA
    10,427
    Wonder if peanut oil works to?
    May 2013
    Toronto, Canada
    73
    I read about that in some thread here. Couldn't hurt and I didn't have any pool lube. This had just never happened before. I guess I should go out and get the proper stuff.
    In any case, it did seem to work though it might have just been a fluke. The whole waterworks' structure is a real mystery to me. The terminology, types of pipes, flow rates, leaks, etc... you name it. Just seems very complicated.
    Philip
    Philip
