Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Fact or Fiction? Aircraft flying over your pool can affect y
    Apr 2013
    Parma / Michigan
    17
    Our local pool store said that planes flying over a pool can affect chemistry, which can be controlled by a product they sell. Unfortunately I havenít seen the product. Is this a fact or fiction?
    Dave (Michigan)
    20x40 IG, Auto Cover, Steel Walls 2R, Vinyl Liner, Hayward Pro Logic SWG, DE Filter, 2hp Pump, Color Logic Light, Diving Board, Typhoon Slide, 4 Jandy Deck Jets, Polaris 280, Hayward Propane Heater & Central Boiler With Heat Exchanger.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Fact or Fiction? Aircraft flying over your pool can affe
    Sounds like a pool store is trying a new sales tactic to get rid of some industrial waste.
    Very much fiction.
    Have that pool store explain how a airplane can affect the water. I bet they can't!!
    Apr 2013
    Parma / Michigan
    17
    Sounded like snake oil to me, but thought I would ask. From what I have heard, they say airplane exhaust can contain unspent fuel, which affects your pool. I think they are right, but only if your pool is at the end of a runway.
    Dave (Michigan)
    Smykowski's Avatar
    Sep 2011
    3,065
    I fly airplanes for a living. Total, complete, utter nonsense.
    Mar 2007
    San Rafael, CA USA
    12,082
    Depends on what the plane dumps into your pool as it flies by.
    Utter nonsense!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Those airplanes (and the black helicopters) can really mess things up for sure. They'll also mess with you, unless you wear an Aluminum Foil Deflector Beanie. http://zapatopi.net/afdb/
    [attachment=0:2yew5vwa]afdb.jpg[/attachment:2yew5vwa]
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Richard320
    [attachment=0:21bt70zn]afdb.jpg[/attachment:21bt70zn]
    Richard please send me a beanie, I have sent you a check for the full $100 that your web ad suggested... LOL (this is a joke people).
    Seriously, I can't believe how stupid the pool stores are or how stupid they think we are.
    Sent via Tapatalk...
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I worked on aircraft in the army. Doesn't matter what type of engine -- turbine or piston -- if you are dumping unburned fuel in your exhaust, you have problems.
    The routine of dumping excess fuel by the commercial aircraft before landing went away a long time ago, when prices went sky high (pardon the pun, please).
    Smykowski, How much reserve time (fuel) do you guys fly with now? 1 hour? Just enough for diversion to a second or third airport? Airlines can't afford to dump that expensive Jet-A anymore, can they.
    Sep 2009
    Greentown, IN
    914
    Love the beanie Richard... that was good for a laugh!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Smykowski's Avatar
    Sep 2011
    3,065
    Regs require planning to land with enough to get to 1st alternate (if required) plus 45 min. We usually land with a lot more than that, but you're right - nearly all the majors are breathing down the regionals' necks to keep that number to a minimum. I've only landed with min fuel twice, and both days were beautiful weather with no nonsense going on, but it's a wierd feeling taxiing to the gate with the fuel gauges in the amber.
    Apr 2013
    Parma / Michigan
    17
    The beanie is awesome!
    Are there any other byproducts from aircraft fuel that would affect pool water?
    Just trying to eliminate all possibilities.
    Thanks for the laugh!
    Dave (Michigan)
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    CHEMTRAILS!!!!!!!!!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Mar 2007
    San Rafael, CA USA
    12,082
    Jet fuel is kerosene (for Jet A-1), mostly composed of straight-chained and branch-chained paraffins with around 10-16 carbons per molecule (usually 12-15). Much of is it not very soluble in water so would form an oil-like sheen on the water's surface. Strong skimmer action could remove it to get caught in the filter (it would likely be attracted to cartridge filter fibers) or one could use a scum ball to help remove it. Enzymes designed to break down hydrocarbons could also be used. So perhaps the product they were selling was something like Natural Chemistryģ Pool Perfect.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I worked KC-135R tanker aircraft for 10 years, occasionally for an emergency they'd have to dump fuel to get down to max landing weight. Even then most of the fuel would evaporate before reaching the ground and if possible it's done over less densely populated areas. I was once on a French KC-135 that the gear didn't retract so right after takeoff we spent about an hour over the Med dumping fuel.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Apr 2009
    Burlington, ON, Canada
    344
    When I asked a local pool store where my phosphates were coming from, they name several sources including airplanes. Seriously. If I recall correctly they said something about the fuel (don't know if they were talking about raw fuel dump, or exhaust or???). Anyway, I tried Natural Chemistry PhosFree and it worked in reducing the phosphate level. However, after reading about phosphates at Trouble Free Pool, I now spend that money on beer.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Quote Originally Posted by rcy
    TFP = Time For Pitchers!!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I guess an airplane flying over could affect your pool......if its a crop duster.
    chiefwej
    4knights's Avatar
    NE Kansas
    419
    Quote Originally Posted by chiefwej
    Nope- crop dusters not allowed to fly over urban areas with chem tanks full. Have corn and wheat fields all around us and the only thing that over flys the pool are the mosquitoes and 4BCT assets from Fort Riley as they head out over the lake.
    I think they may be having mechanical issues though because they seem to hover every time my wife or daughter are out by the pool.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    kyser's Avatar
    Jun 2013
    Orange City, FL
    47
    I think I need to make one of these; they just used their psychotronic powers to make me waste thirty minutes on their website. That's some funny stuff!
    6.7K Pro Series 18x48, VL40T32 pump/filter, Hayward skimmer, TF100, and BBB!
  20. Back To Top    #20
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Quote Originally Posted by 4knights
    Sounds like my unit (heli transport) when I was stationed in Ft Polk, LA. Seems like a lot of "overnight training flights" needed to be done during Mardi Gras.
    Yes, I'm a rotorhead. Can you go get me some flight line and rotor wash?
