Thread: Vinyl Liner Vacuum Recommendations?
    It's time for a new pool vac. Anyone have a preferred brand or style that is better than another? My pool is a classic rectangle with deep end and lots of straight line angles.
    new pool owner, 35k gal, trichlor tabs in chlorinator, IG, vinyl, sand, Hayward superpump, aquacal heat pump
    bbodb1's Avatar
    Jul 2013
    Central Arkansas
    103
    Re: Vinyl Liner Vacuum Recommendations?
    I have had a Kreepy system and currently have a Dolphin system. Both of these system experience issues in covering an odd shape pool (which is what I have) but since yours is rectangular, you should not have that concern to the degree that I have had.
    Having said that, something to think about with respect to the Kreepy system is that it works in/with your basket returns(drains). You plug (cover) one drain and connect the Kreepy to the other drain. I feel like some water quality problems I've experienced may have developed from the area near the plugged drain but that is unsubstantiated.....
    Also, the Kreepy does NOT require power - it works from the water suction of your return basket.
    The Dolphin system requires a nearby electrical outlet. Putting an electrical cord in a pool seems wrong on so many levels but the Dolphin cord is fairly well protected/padded. Still, I wouldn't swim while the Dolphin is in the pool - something you can do with the Kreepy.
    The Dolphin will likely clean better - and is more likely to cover the entirety of the pool.
    You will have more hands on time with the Dolphin (placing in the pool, taking out of pool) but it is a pretty quick process.
    You'll have to leave the Kreepy in the pool longer to achieve cleaning AND you may not be able to clean all of your pool with your Kreepy if you don't get enough hose. If your pool has unequal suction through the return baskets, you may find the Kreepy doesn't work so well connected to the return basket with less suction.
    Food for thought...
    20K gal, IG vinyl, Waterfall on 2nd pump (1HP US Motor), Dolphin cleaning system, Central Arkansas, installed 1999
    2 Haywood Super Pumps, 1HP (main and waterfall pumps), Purex Triton II (TR 60) Sand Filter (replaced original 2016)
    I have had a Water Tech Blue Pearl for years and it rocks.
    IGVP 20X40 30,000
    Hayward 1.5gpm Superpump
    Blue Pearl Robotic Cleaner
    Dad, can we go in yet?
