Results 1 to 7 of 7
Thread: White areas on wall where algae used to be
    Jun 2013
    Broken Arrow, Ok
    19
    I'm on day 2 of killing the algae. I've maintained shock level, the water is clearing up nicely but I noticed today that areas of white have replaced where the algae was hanging out on the pool wall. When scraped they can be removed. They cannot be removed with the nylon pool brush. What is this?
    12,000 gallon SWG - IG Medium grey plaster - Water Sheets, Spillover Spa and 28ft x 4 ft tanning ledge
    Hayward High Rate Sand Filter - ProSeries - 2 pumps - 1 variable speed, 1 two speed
    Hayward Heater - Hayward Pro Logic Automated Digital System with wireless remote
    Pool build June 18, 2016 - TF-100 Test Kit with Speedstir - Hayward SharkVac
    22,548
    Re: White areas on wall where algae used to be
    It sounds like scaling.
    Can you post a set of test results and how you got them?
    Jun 2013
    Broken Arrow, Ok
    19
    I have the Taylor K-2006. My last full test results were as follows:
    FC 24.5
    CC 0.5
    PH 7.4
    TA 140
    CH 300
    CYA 40
    Thanks for your help!
    22,548
    With those numbers you could scale during the shock process. Especially if the pH went up. Once you're done shocking Keep your pH near 7.2 and they should dissolve over time.
    Jun 2013
    Broken Arrow, Ok
    19
    Great, thanks Dave!
    Aug 2010
    Dallas, TX
    4,052
    Since you have plaster, you might try a wire brush also. Finding that I could use one was one of those life changing situations.
    Jun 2013
    Broken Arrow, Ok
    19
    I have a wire brush on the way, thanks Robbie H!
