Results 1 to 8 of 8
Thread: New, draining, convert baquacil to chlorine, help!!!
    [*]hi, the name is Jamie, just had my pool for 3 weeks, having to drain to repair a side and want to convert while I'm down.
    Jamie
    18' round ag 7600gal soft side intex
    Krystal clear 1500 gal/hr cartridge filter
    Set up 6/10/13, baquacil for 3 weeks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New, draining, convert baquacil to chlorine, help!!!
    Welcome to tfp, Elzannajamie
    Have you reviewed the pool school article on the conversion yet?: http://www.troublefreepool.com/pool-...ine_conversion
    Nope, but I will be sure to before I get started with anything, draining the pool right now.
    Jamie
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Why are you draining the pool? Our conversion process is typically done without draining...what type of pool do you have?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    If it is an above-ground pool, which it sounds like, don't empty it 100%. You might end up with wrinkles in the bottom. Leave about a foot of water in the pool if you can.
    And take pictures of the colors changing. We like that.
    Oh - and Welcome!
    I have to drain because I have to reinforce a side that washed out with a recent storm.
    Jamie
    Do I have to go thru the whole long process if I completely drain my pool? Or can I just scrub the whole thing down with 50/50 bleach and water and start again?
    Jamie
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by Elzannajamie
    You'll need the whole process. The good news is, it won't take very long. But there's still going to be residual in the plumbing and stuff you missed in the pool.
