Thread: Extreme Heat levels
    Extreme Heat levels
    I am in CA and in the middle of 111 degree heat. What do you guys recommend I should keep my FC levels at? I have been trying to keep around 5 but thinking I should go higher? Is there anything else I should watch out for? Tomorrow is supposed to be 114. Man O man is HOT!
    Re: Extreme Heat levels
    It all depends on what your CYA level is.
    22,539
    The temperature doesn't matter. Just keep it within the recommended range for your CYA level.
    Mar 2007
    San Rafael, CA USA
    12,082
    Though some pathogens grow faster at hotter temperatures (some algae slows down in growth when you get too high), chlorine also reacts more quickly and actually outpaces the pathogen growth. So you shouldn't need to use a higher FC target, BUT the rate of chlorine loss will be greater from reacting with organics in the pool and from outgassing. Even so, most loss is still from sunlight and that is independent of temperature.
