Results 1 to 10 of 10
Thread: Swimming Pool Gas Heater - runnng a pipe above ground?
    Will it help to heat pool faster if I run outflow pipe from the heater above the ground?
    Thanks.
    Andy
    Chicago, IL
    IG 20'000 gal
    18 x 36 ft
    Cartridge
    Re: Swimming Pool Gas Heater - runnng a pipe above ground?
    No, it won't make any detectable difference.
    What is heater outflow water temperature in general?
    I feel a little warm water coming from my inflow pipes.
    Thanks.
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    It will be warm, not hot.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Why not hot?
    mas985's Avatar
    Pleasanton, CA
    11,741
    It depends on the heater BTU output and the flow rate through the heater. For example, a 400k BTU heater (80% efficient) and a 70 GPM flow rate will raise the water temperature about 9 degrees. Half the flow rate, doubles the output heat rise.
    Mark
    Feb 2013
    Yukon, Oklahoma
    220
    I assume you are asking because you feel your pool isn't heating up fast enough? Do you have one of those bubble type solar heaters laying on top of the water? If you don't I would recommend you look into it. Your loosing heat at a pretty good clip, you need to slow it down......it will make a good difference on the heating bill too (preventing heat loss).
    Bob E.
    I always thought that air is a bad heat conductor and pool loses heat through the walls to cold ground around it...
    Heat loss occurs through evaporation, covering the water will work best. My cover saves me at least 5 degrees on cool nights.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    mas985's Avatar
    Pleasanton, CA
    11,741
    Still warm air has a little lower heat transfer than dry dirt but with significant wind or low air temps, dirt is better. However, in terms of heat loss in a pool, evaporation and radiation are the two highest components of heat loss. Conduction is fairly small because the ground (dry dirt) is a pretty poor conductor of heat.
    Mark
