Results 1 to 11 of 11
Thread: new neighbors numbers
    I need some advise for my neighbor who is using tabs, todays first numbers:
    PH 7.5
    FC 6
    CC 0
    TA 50
    CH 810 Yup that's right!
    CYA 50
    Temp 85 full sun
    I don't know if the CH results through the rest of the numbers off but here they are, advise gurus!
    Roth
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: new neighbors numbers
    Did you do the test with one of our test kits ?
    Jeff
    yes daves TF100. sorry
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Things don't look too bad. TA could be a bit higher. As for the CH I think the tabs could be the prob. By the way what type of pool does he have ?
    Jeff
    inground plaster sorry,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The high CH is the main concern. Only way to lower is replace some water. Should be between 250-350.
    Jeff
    Jason what say you braaaa?
    38,371
    Unless they are using the rare cal-hypo tablets, the tablets are not the high CH source. Since the CYA is now at 50, you should get them to stop using the tablets and switch to bleach. Leave the TA and keep the pH on the low side to counter the high CH and keep in the acceptable CSI range.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    There ya go.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    They stole my water sample!
    When CH starts getting that high, you really need to watch TA & pH. Plug the numbers into the pool calculator and see what the CSI is, then play with the parameters and get a feel for how close to scaling its is, and what even small changes to pH and TA can do. Incidentally, that pol is a prime candidate for using the 10 ml sample size. At that level, whether you read 800, 825, or 810 it doesn't make a lot of difference. What's the CH of the fill water? If it's high, the drain & refill scenario isn't as satisfying as it could be. Rainwater is another story. Encourage them to harvest as much of that free Calcium-free water as possible when it rains.
    Thanks All, I told him so now its all his, I showed him this site also and thanks everyone for the advise.
    R
