Thread: Intex 1,600 gph sand filter motor bearings
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Ok a week or 2 ago my pump motor got loud and then died. I have a 1,500gph cartridge filter to use as a backup but its a lot weaker than the 1,600 pump so yesterday I tore the 1,600 pump apart and my first thought was bent shaft, but then I noticed the shaft was fine. So I used some carb and choke cleaner and cleaned the motor up. It works fine for now but I need to replace the bearings.
    I could tear it down and measure them but I'm hoping someone on here can give me the correct bearing size? I'm sure I can safely replace them.
    I wonder if the 1,500 bearings would work? I plan on selling the 1,500 so I don't want to tear it apart for nothing.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    22,549
    Re: Intex 1,600 gph sand filter motor bearings
    I don't remember anyone tearing one apart and reporting what the bearing size is. If you find out, it would be nice to post it for someone in the future.
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Well I tore the 1,500 GPH pump apart and it doesnt have bearings. So that answers my question on if I could just swap over the bearing.
    I think my 1,600 sand filter pump over heated so Im going to tear it down and see if I can get some new bearings in it. I will try to make a tutorial with pics s I cant find anything on the subject of replacing intex bearings. I would think its possible from what I seen well I had it apart last night.
    I can tell that they use cheap bearings and from googling my issue it looks like many of these pumps have been replaced when the bearings go. I would rather save a few bucks and just replace the bearings with quality bearings.
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Well pulled it apart and sure enough the front bearing is shot.
    I got a bunch of pics for a tutorial.
    The bearing is marked C&U 608Z seems like I should be able to find them hopefully I have something in my junk pile I can salvage 1 from to get it running until I can order a new set.
    EDIT: The bearing is found in most rollerblades and skates. Luckily my son had an old pair of heelys that I was able to use the bearings from.
    Tutorial with pics coming at some point this week.
    These bearings can be had for 2 bucks way cheaper then buying a whole new setup...
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Skate bearings. Who'd have thought?
    Thanks for the info! I've got 3 boxes of 6 that I bought intending to use for a linear slide for a home made tool. Maybe I should just keep them on hand.....
    Jul 2009
    S. California
    157
    Great find! Thanks for the info which I will remember but hopefully never need.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
