Thread: Correct instructions for adding pH reducer...and then what?
    Jun 2013
    Paphos, Cyprus
    4
    I am getting totally confused about the correct way to add pH reducer to my pool.
    These are my questions:
    1. Do I dilute dry acid in water first?
    2. Do I add the dry acid in the deep end, shallow end or evenly around the pool?
    3. Do I add the dry acid with the pump running or off?
    4. If the pump should be running, how long do I let it run for?
    5. If the pump should be off, when do I put the pump back on? Is it minutes, hours or days?
    My goal is to reduce pH and TA. My pH is 8.4 and my TA is 240+
    6. Do I add the dose once a day?
    7. When do I repeat the dose and do I let the pump run in between? Is it hours or days?
    Thank you.
    33,500 US gal., Sand Filter, Inground, Vinyl (new), 2hp pump
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Correct instructions for adding pH reducer...and then wh
    Quote Originally Posted by cathandbrian
    You can, but not required.
    Personal preference would be to broadcast evenly.
    Definitely running. Always add your chemicals with pump running.
    Best is to turn on pump 1/2 - 1 hour before testing, and wait 1/2 hour between differing chems.
    As stated above, running, and leave it on for at least an hour after treating your pool
    See Pool School for more details.
    You will need to dose several times a day, bringing your pH down to around 7.2, point a return to the surface or if you have a waterfall/fountain, turn that on. Idea is you need to aerate the water, which will bring the pH back up. Try to keep it between 7.2 and 7.6.
    While reducing TA you will need to run 24/7
    Thank you.
    Do you do your own testing? If so, with what?
    Most dry chemicals, including dry acid, are best pre-dissolved in a bucket and then poured slowly in front of a return with the pump running. Then leave the pump running for an hour afterwards.
    Given your PH, this should be done soon.
    Jun 2013
    Paphos, Cyprus
    4
    Thank you for your replies.
