Thread: GFI plug on Intex pump submerged
    The (unplugged) GFI plug on my pump was submerged overnight and now the pump is not running. The Reset button turns on the indicator light like it should and the Test button does not illuminate the indicator light which is also good. But the pump won't turn on. Will it help if I disassemble the GFI plug and dry it out? Thanks
    4k AGP. Intex 637R 1,000 gph pump w/Type A cartridge. New 2012. Chardon, Ohio.
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: GFI plug on Intex pump submerged
    why dont you try another plug first and make sure its not your pump. then if it's fine, kill the breaker and dry/maybe replace the plug.. I would almost just replace it at that point.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    The cord has the GFI on it, so the wall outlet is not the problem. I will try to dry the GFI plug and see it that works. If not I guess I'll have to rewire a new plug on. Thanks!
