Results 1 to 8 of 8
Thread: My TA is zero???
    My TA is zero???
    Have a intex 15 x 42 pool. With the little pool filter system that it comes with.
    Had my water tested cause after battleing algae at the opening of the pool it is still cloudy.
    Leslie's water analysis report
    Free available chlorine. LOW 0
    Total available chlorine. LOW 0
    Calcium hardness. OK. 200
    Cyanuric acid. OK. 60
    Total alkalinity. LOW. 0
    Any suggestions?
    Leslie's suggested ALKALINITY UP 8 - 10 lbs?
    Does anyone know if this sounds right or not?
    Thank you for any help
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My TA is zero???
    Welcome to tfp, moyo345
    Do you have a measurement on ph? If your TA is really 0 then your ph should be very low (although most tests will only read down to 6.8 ph).
    Sorry ph result was 7.2
    The sales person said the test equipment they use does not show any alkalinity at all
    Thank you for the welcome
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    First welcome to TFP.
    Second don't let the pool store test your water.
    Third get one of our recommend test kits. The TF 100 is a good one.
    Fourth. Read pool school.
    What was your PH ? Get some chlorine in there also.
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can raise TA and PH at the same time using Borax. I've never seen a TA of 0.
    Jeff
    The sales person said their test only went down to 6 on TA and my sample was below that
    Have been adding Chlorine daily. System uses the 1" tabs in the filter. Been adding 4 or 5 daily as they dissolve.
    Read pool school and other topics when had an algae issue at start of the season. Was very helpful in clearing up that issue.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you want to use the BBB method you need to test your own water with one of our test kits. It's all about you taking control of your water chemistry.
    Remember the pool store is in business to sell you things you don't need like those pucks. .
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you ph is 7.2 ,your TA can not be close to 0 ppm. As pwrstrk said, pool store results can be very inconsistent. In your case they are obviously wrong. See this link for recommended appropriate test kits: http://www.troublefreepool.com/pool-...kit_comparison
    What type and size of pool do you have?
