Results 1 to 7 of 7
Thread: Using up Trichlor I know I know..don't have that much
    Mar 2012
    Lewisville, Texas
    71
    Anyway I don't want to let them go to waste and I'm not going to sell them to someone.
    http://www.intheswim.com/Pool-Chemicals ... e-Tablets/
    This says 25 tabs per 10000 or 55 tabs basically for my 22000 gallon pool. Does this sound accurate?
    It doesn't mention if thats with a certain CYA level or anything. I have one 25 pound bucket of 1" tabs. I think it was 25...anyway.
    Since the CYA will go up as I use the tablets...it wouldn't take a static number would it....heh
    I'm so not clear on how to use those things.
    Thanks in advance
    Lewisville, Texas 22,000 Gallon IG Plaster Chlorine FNS Plus Vertical Grid D.E. Filter 60 sq. ft. 150 GPM Push/Pull Valve Hayward Ecostar SP3400VSP Baracuda Zodiac G3 Cleaner
    Caldera Vacanza Marino Vanto Spa VMA4R6393
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Using up Trichlor I know I know..don't have that much
    What is your current cya level?
    We recommend a cya level for you pool of 30-50 ppm.
    25 lbs of trichlor tabs will raise your 22000 gallon pool by 76 ppm cya. It will also continually lower you ph and TA.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    76 ppm CYA ouch !! I wouldn't use it.
    Jeff
    Mar 2012
    Lewisville, Texas
    71
    Quote Originally Posted by linen
    0 I'm using 2 pool misters/coolers to cool the pool which will raise pH. I suppose it won't raise the TA, but if that gets too low I can raise it if needed right?
    I had a leak that got rid of all the CYA. We fixed the two leaks we had...I think air bubbles are coming out of the return that had the leak..so perhaps the repair broke...I hope not.
    There is one more minor one in the skimmer, but it shouldn't lower CYA really fast.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yea but the CYA level will skyrocket if you use all of it.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by Raiken3712
    Thanks in advance
    Weigh 'em. Then check out Effects of Adding Chemicals in http://www.poolcalculator.com/ That should enable you to figure out how many you can use without overdoing the CYA.
    As long as you keep the bucket closed and the pucks dry, they'll keep a long, long time. Then you'll have them for vacations.
    Mar 2012
    Lewisville, Texas
    71
    Quote Originally Posted by Richard320
    Thanks in advance
    Thanks will do.
