Results 1 to 7 of 7
Thread: Do anything special after swimmers?
    May 2013
    New Jersey
    176
    Do you do anything additional or special after swimmers, particularly regarding chlorine if levels seem ok? (This may be a dumb question but searched everywhere for answer and couldn't find it.). Tested FC this morning and was 4. Then tested about 2 hours after swimmers and it was 3, where it normally is at that time every day. Therefore, seems we hardly lost any due to swimmers. Had hubby raise to 5 but wondering if we should add more since we had swimmers. We use strictly liquid chlorine, no tabs.
    FC 3 last time checked but in process of raising to 5
    PH 7.5
    CYA 40
    TA 90/100
    7+ years, inground, 25,000 gallon, vinyl, sand filter.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Do anything special after swimmers?
    You're good to go if you checked fine afterwards.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Pick up the wet towels....
    Mar 2010
    Spring, TX
    1,082
    If you only lost 1 PPM I would say you are fine. Just bring it back up to the correct level and you are good to go. Usually if I am going to have swimmers I will bump it up 2-3 PPM about 30 minutes before.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    I would check the CC (combined chlorine) level and increase the FC, if necessary.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Roughly speaking, the chlorine demand from bathers in a pool will be around 1 ppm FC in 1000 gallons for every person-hour. So for your 25,000 gallon pool it would take 25 person-hours to see 1 ppm FC of chlorine demand. That's why you normally don't notice it. Of course, if someone urinates, that's different. Even so, it would take 4 cups of urine in your 25,000 gallon pool to create a chlorine demand of 1 ppm.
    May 2013
    New Jersey
    176
    Thanks! All great info
