Results 1 to 16 of 16
Thread: LED Pool Lights
    Jul 2009
    Houston
    74
    LED Pool Lights
    We have a 17k gallon pool that was constructed in 2008. The pool has two lights, at either end, located about mid way between the pool surface and bottom. The lights are 500 watts each.
    Recently, our neighbor had a pool built, and the builder installed multi-colored LED lights, with an equivalent light output of 400-500 watts (don't recall exactly). Now my wife wants the led lights for our pool, but we keep hearing that led bulbs cannot be placed in enclosed fixtures. That said, the fixtures are under the pool surface, and the enclosures handle 500 watt incandescent bulbs. So I can't imagine there would be an issue with LEDs in the enclosures.
    Couple questions. Any idea if the led bulbs would be suitable for the type of fixtures typically installed in 2008? If so, any recommendations as to where to buy these things or the brand of bulb? As noted, she would like a 400-500 equivalent LED bulb that changes colors.
    Thank you (this forum has been a lifesaver).
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Re: LED Pool Lights
    If your light niches are the industry standard, LED lamps will install right in. They are not cheap however. Here's a couple of examples:
    http://www.zodiacpoolsystems.com/Pro...olors-LED.aspx
    http://www.pentairpool.com/pool-owne...lor-led-74.htm
    We really like our LEDs. The changing colors make the pool look great at night.
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Jul 2009
    Houston
    74
    Re: LED Pool Lights
    Thanks for the links. From reviewing this on the Net, Pentair seems to be the way to go. But our pool contractor recommends the Jandy color LEDs. Does anyone know if one is better quality than the other? Our main concern is quality manufacturing. Btw, for the cost charged by both companies for these lights, I'm amazed that they only come with a 1 year warranty (which seems to be the case for both Jandy and Pentair).
    Thanks!
    Jun 2011
    Long Beach, CA
    2,781
    Re: LED Pool Lights
    If you have the right light fixture, you could install one of these, http://www.poolsupplyworld.com/3greplacementbulbs.htm. I have Jandy lights so I can not use them. If you can use these, make sure you replace the gasket that seals the light.
    Jun 2013
    South Florida
    2
    Re: LED Pool Lights
    Quote Originally Posted by ping
    Yeah these work great at about half the cost of installing a new fixture. I replaced my standard bulbs in both pool and spa with these LED units and the color schemes are awesome. It only took about 20 minutes to change them out. If you have the extra money to spend the Pentair or Hayward Colorlogic will give you a few more color combinations but thats about all.
    Patrick in Fla
    Jul 2009
    Houston
    74
    Re: LED Pool Lights
    Thanks for all the info.
    Assuming we need to replace the fixture, does anyone have impressions regarding the Jandy LED system versus the Pentair led 5G system?
    Thanks again!
    Mike_W's Avatar
    Aug 2011
    142
    Re: LED Pool Lights
    Do you have or are you planning to get an automation system? If so, compatibility with the system would be a major consideration. We chose the Jandy's because they are compatable with our iAqualink automation. I have no reason to think that the Pentair would not be of equal quality to the Jandy. My Pentair pump and filter seem to be well made and perform great.
    Mike
    Jul 2009
    Houston
    74
    Re: LED Pool Lights
    Thanks. We have Jandy equipment all around (including a variable speed pump we just bought to replace our five year old 2HP pump), so I went with the Jandys. They have not yet been installed, but I am happy to hear about the automation feature.
    Jun 2015
    Murfreesboro
    29
    Re: LED Pool Lights
    I have brand new pool with all Jandy equipment with Aqua link automation. For some reason the builder installed Hayward universal color logic LED lights. Does anyone knows if Jandy automation system will work with Hayward lights
    Aug 2014
    NJ
    435
    Re: LED Pool Lights
    I believe they work with Hayward Color Logic. My iAqualink 2.0 has that listed as an option to choose on my setup page for lights
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Sep 2015
    Mesa, AZ
    305
    Re: LED Pool Lights
    I am considering Savi Melody LED lights. Does anyone have these lights and how do they look?
    4knights's Avatar
    NE Kansas
    419
    Re: LED Pool Lights
    Quote Originally Posted by azjoshers79 View Post
    I have 2 of them and love the colors!
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: LED Pool Lights
    I just installed these two led bulbs in my pool...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Sep 2015
    Mesa, AZ
    305
    Re: LED Pool Lights
    Quote Originally Posted by 4knights View Post
    Is the interior surface of your dark or light. I have been ready that the LED lights do not look as good with the darker interiors.
    Freeform /620 Surface/110 perimeter/20k gal/ Raised bond beam/Baja shelf (2)//Pentair- Intelliflo VS pump, Pentair Whisperflo 1hp// Easytouch, C&C 520 Cartridge, Intellichlor SWCG// A&A- Magnasweep in-floor, LeafVac, Venturi Skimmer,// Mini-pebble (Aqua Blue w abalone shell)//4 Pentair Globrite LEDs//3 sheer descents//Travertine coping and decking.
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    Re: LED Pool Lights
    Darker interiors require more lights. The Savi lights will do fine if your builder installs enough of them.
    Since you're going with the EasyTouch control, be sure to request the P-Series lights so the controller can address the colors.
    Take a look here: http://savilights.com/product-savi-melody-p.html
    Edit: The Melody SOL series is apparently twice as bright as the Savi Melody, so that may be a better choice. http://savilights.com/product-melody-sol-p.html
    APSP Certified Building Professional
    APSP Certified Service Professional
    NSPF Certified Pool Operator
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: LED Pool Lights
    My wife and I argued endlessly over regular lights and the Jandy Watercolor LED's. I argued that since we were building the pool we should do it right and do it the way we wanted. She balked at the cost but finally aquiesced. My wife is stubborn but she now admits it would have been a huge mistake not to put them in. My nieces and nephews were here last weekend and they stayed late enough for the lights to come on. They were so excited they begged their parents to stay a while longer which they did. I have never seen kids so excited. We put on a few different lights shows and they had a blast. It makes for a completely new swimming experience. Get them and enjoy!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
