Thread: Stabilizer
    Stabilizer
    How long should you stay out of the water when adding 4lbs?
    14,000 gallon IG plaster pool, Cartridge Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Stabilizer
    Quote Originally Posted by thabeezer
    Just tie it up in a sock so it's hanging in front of a return and get in.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,431
    Re: Stabilizer
    I walked around IN the pool while I squeezed the sock with the stabilizer in it. No big deal.
    Kim
