Thread: New to BBB...look out bleach isle I'm comin'
    gonzoTG's Avatar
    Jun 2013
    Erie, PA
    9
    Just got my TF test kit. Here's my first set of numbers..
    FC- 5
    CC-1.5
    TA - 90
    CH -150
    CYA 50-60 (first two readings)
    pH- 7.2
    Per pool school, based on the CC I need to be in shock process so per the calculator I am off to get some bleach. Based on the guide I think I'm fine not adjusting the pH until after process is over and all others are pretty much in line although CYA may be a little on high side.
    Any other recommendations getting started? Does it make sense to do overnight chlorine loss test in day 1?
    18K IG Vinyl
    Jandy 24ST Sand with 1HP Hayward Superpump
    Paramount 6 way distributor valve
    Teledyne Laars Model ESG (gas) Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: New to BBB...look out bleach isle I'm comin'
    When the water is clear and you're getting .5 or less CC, then worry about the overnight test.
