Thread: Intex 2650 sand filter - low flow
    Jul 2012
    Northern California
    21
    I picked up an Intex 2650 sand filter for my AGP a few months ago. Its been running well, but this morning I realized its running with really low flow. I turned the pump off, and move it to recirculate and turned it back on to see if it was the pump or something else. The flow almost doubled (used unscientific method of feeling the inbound flow with my hand). I turned the pump off again, move the valve to filter, turn it on again and the flow cut way down again. My pump pressure is a bit low maybe 8 psi (usually runs closer to 10). Should I backwash this thing? What am I missing?
    Thanks!
    --Jonathan
    19,000 IGP TF-100 test kit w/ SpeedStir
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: Intex 2650 sand filter - low flow
    try backwashing it.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    Jul 2012
    Northern California
    21
    Wow, okay, so flow has tripled now (unscientific method used again). I thought I was supposed to wait until the pressure gauge increased by 10 PSI over normal. Whats the deal here? When SHOULD I backwash my filter.
    Thanks again guys!
    --Jonathan
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by jspeacock1978
    Thanks again guys!
    --Jonathan
    Backwash & rinse when the psi increases 20 to 25% above clean pressure reading.
    You're done SLAMing when:
