Thread: In the pool lighting?
    Jun 2013
    Lawrenceville GA.
    53
    Not sure where to put this so I just stuck it here.
    I was wanting to add some lighting inside the pool itself. My pool currently does not have lighting in the pool but I do have plenty of lighting outside and around the pool. I don't want to hard wire a light in the pool. Any suggestions on other options to get lighting in the water or around the edges under the coping without having to hard wire it in? I've seen the floating lights but I'm not sold on that idea yet.
    16x32 IG, 24k Gallon, Vinyl, Sand filter, SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: In the pool lighting?
    This may not be a great idea, but if your wall is metal, you could use something like this: http://www.poolsupplyworld.com/GLI-7...ON-3-13112.htm We use two of them on our metal walled agp, though they do not put out a ton of light.
    Jun 2013
    Lawrenceville GA.
    53
    Wall in not metal but I like the idea. Would be cool to have a few of them around the edges under the coping.
