Thread: Layout question
    Layout question
    We are just starting the process. We have a wide but shallow back lot. Here is the first pool builder's idea. He stopped by one afternoon and after a brief walk around he created these. I had thought the deep end would be flipped as the larger part of the deck would be a hang out area and have always thought that would be better for young ones and no cannon ball splashes. Do you usually dictate the deep with the entry into the yard. I will be putting in an above ground spa as well, but not sure where a good location would be. On the right side of the back is our bedroom door and another door for a pool bathroom (we knew we would have a pool). The hammock in the corner was something he added, I was thinking maybe like the pavilion in the picture below behind our bedroom (close to the shallow end if we flip the orientation). Any suggestion or comments. The pool is drawn as a 20x40 vinyl with a nice coping and full stairs across. I probably can't afford to do all the concrete in stamped or anything too fancy. It seems like the regular concrete is affordable, but once you add something to it, it doubles. I will also probably run the fence off the corner of the back right end of the house. Any suggestions?
    TN/KY area and looking to build a IG vinyl pool by summer of 2013. Starting the bid and planning stage.
    Re: Layout question
    more pics that did not publish
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Layout question
    Scan my build thread decided-to-build-first-pool-this-spring-t41345.html
    I highly suggest making the first step 3-4' wide, like a tanning ledge, kids love ours.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Re: Layout question
    Does anyone else have the entry into the back yard in the deep end of the pool?
