Thread: Sand pump dies it need chemicals added to water?
    Jul 2009
    Sioux Falls, SD
    6
    We have just got a intex sand filter pump and I see nothing about if chemicals are also needed to add to the water? Any help would be great
    Jenn
    AG INTEX 16ft X32ft X52" RECTANGULAR ULTRA FRAME POOL , approximate 14364 gallons filter is Cartridge Intex size B and output is 2000 gallons a hour, has a SWG.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Sand pump dies it need chemicals added to water?
    All you've done is upgrade the pump and filter - it's still the same water and has the exact same needs it always had. The filter will not remove algae, if that's what you were hoping for.
    Do you have a test kit? Can you post readings? How does the water look?
