Results 1 to 11 of 11
Thread: Don't know how to vacuum pool
    Jun 2013
    Louisville, KY
    65
    I have the hose hooked to the vacuum with pole attached. The hose is filled with water. I was told to put the other end of the hose into the hole right directly under my skimmer but there's no suction. Is there something else I'm supposed to do?
    21ft round Doughboy AG, 9,300 gallons
    22 inch ClearWater Sand Filter
    1 HP Hayward Power Flo Matrix Pump
    Install 6/16/13
    TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Don't know how to vacuum pool
    please descibe..........."under" your skimmer. Did you mean under the skimmer basket?
    Jun 2013
    Louisville, KY
    65
    So sorry, lol. The hole is inside the pool under the opening to skimmer.
    Install 6/16/13
    TF-100 Test Kit
    Apr 2010
    East Texas
    9,655
    Is there a valve you need to switch over perhaps?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Hmmm are supposed to at that point plug the skimmer? What is in the bottom of the skimmer?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Mar 2011
    Grand Rapids, Michigan
    279
    I think you may have to rotate your skimmer cover by 1/2 and set down into the skimmer itself. Is there an arrow on your skimmer cover?
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Jun 2013
    Louisville, KY
    65
    When I lift the basket out there's just a hole there. There is isn't a valve or anything.
    Install 6/16/13
    TF-100 Test Kit
    Mar 2011
    279
    There is a vac port under the skimmer on the inside of your pool, correct? Do you have a small adapter that sticks into the the vac hose and then into the vac port?
    Jun 2013
    Louisville, KY
    65
    I figured it out! I had to turn the pump off then put the lid to the basket down inside, then turn it back on. Thanks for helping!
    Install 6/16/13
    TF-100 Test Kit
    Jun 2013
    Louisville, KY
    65
    The lid also acts as the sealing plate for vacuuming
    Install 6/16/13
    TF-100 Test Kit
    Mar 2011
    279
    YIPPEE! You got it. I have a Doughboy also but mine is quite a bit older than yours. Installed in 1985.
