Results 1 to 7 of 7
Thread: pump/filter to waste?
    mariane's Avatar
    May 2012
    Southeast Michigan
    298
    Always wondered: why use "pump to waste" or "filter to waste" while vacuuming? Why not just leave it on filter setting? Does it change the way debris is collected, and bypassing the filter is better? Or vacuuming algae into the filter is a bad practice (which the pool store said)?
    Thanks. Yours is my "go to" site for all pool info.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    30,395
    Re: pump/filter to waste?
    A pool with a whole lot of debris will quickly clog up most filters....just too much junk. Vacuum to waste puts the junk overboard and it never gets to your filter. Generally, wastes quite a bit of water if you have a strong pump.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    I use a whoooole lotta less water when vacuuming just plain old dirt to the filter and backwashing occassionally. I got to have a bunch of "extra" water to do the waste thing.
    mariane's Avatar
    May 2012
    Southeast Michigan
    298
    Thanks for the replies duraleigh and woodyp. Good to know.
    Is the pool store correct in saying "never vacuum to filter when trying to clear up algae that is settled on the bottom of the pool (but no other debris)?
    Thanx
    30,395
    Never say never! I cannot afford the loss of water so I only vacuum to filter. Others have a different situation.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Quote Originally Posted by mariane
    Thanx
    No.
    If it's great chunks of leaves and twigs, you'd want to keep that out of the filter. But dead algae buildup is pretty fine stuff, and the filter is designed to catch it. When the gauge starts climbing and the flow slows down, that's a good sign. It means the filter's working. Then you backwash. The filter's designed to be backwashed - that's why there's a setting called, not surprising, backwash.
    mariane's Avatar
    May 2012
    Southeast Michigan
    298
    Thanks for all the great replies. You are all great!
    Should have known better than to believe the one guy at the pool store who does not even own a pool.
    Yep. That's right.
    A guy who works at the pool store who does not even own a pool.
