Thread: How to clean up my new pool bottom before I put my liner in
    I'm trying to find the best way to clean up my vermiculite in my pool before I put liner in .. I've got it sanded out but is still rough .. I have some cracks and pits I know will show ?? What can i do??
    Can I put a grout mix on top of vermiculite to fill in the pits and to clean it up .. Plzzzz help
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,991
    Re: How to clean up my new pool bottom before I put my liner
    Welcome!
    I have no firsthand experience to offer, but I'll bump the thread up so others see it.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I don't know how you do it, but you do want to do it. I'd also get out in your pool tonight and shine a flashlight across the various surfaces, then have a helper circle issues with a pencil so you can fix them in the daylight.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Feb 2012
    Maryland
    400
    Quote Originally Posted by harleysilo
    This is exactly what we did, we used sidewalk chalk and outlined areas that needed work. We then mixed up a wet vermiculite mix in a bucket, I did 1 part vermiculite to 2 parts portland. I am not sure how much water I put, but it was wet, almost soupy. I then used a trowel I had for doing tile work and worked it in like that feathering it in. Finished it off with some light sanding.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Thanks will check it out at night .. I have some pre mix vermiculite that's not working vary well but I'm going to try to add some Portland cement and see how it dose .. Thanks
