Thread: Soft Scrub With Bleach
    May 2008
    Just curious what the thoughts are on using this product for cleaning up around the pool at startup. I have been using this for a couple of years upon opening to clean the vinyl above the waterline and to clean the fiberglass steps and slide. I have seen no ill effects from usage, just curious what other products people may be using. I wet down the vinyl before application and spray vinyl after brushing with a soft brush. Any suggestions?
    16x32 IG vinyl
    24000 gallons
    Hayward super pump 1.5HP
    Hayward Pro Series Filter S244T
    3 returns, bottom drain, skimmer
    twenton7...I have bin using soft scrub for the last few years also. I have had no bad effects with the water or fiberglass with this product. I also use a Mr. Clean Magic Eraser with it.
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    Mar 2007
    I just take a bucket and mix bleach with water 8)
    27' Round AG, 17,200 gallons, sand filter
