Results 1 to 9 of 9
Thread: SWG or Baquacil
    Jun 2013
    Michigan
    2
    SWG or Baquacil
    Our pool is being installed this week. We have to decide between going with a SWG, which I think I would prefer, and Baquacil, which is coming highly recommended by the pool store owner.
    The SWG we'd use is the Hayward Goldline AQ-TROL-RJ AquaTrol Above-Ground Pool Return Jet Chlorinator. The pool store owner is telling me that using this would void our warranty and basically only had bad things to say about swg's...great for the first year then the danger begins...corrosion...maintenance...won't even be an option in a few years because it is so inefficient.
    She happens to be the only Baquacil distributor in our area. She raves about it. I'm finding so many mixed reviews online.
    My 1 yo daughter has extremely sensitive skin/eczema, so I'm trying to find the best option available for her and the rest of our family. I would love some feedback on both of these options. Thanks
    11K gal, AG 15x26x54, 18" Hayward sand filter 1 1/2hp
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: SWG or Baquacil
    Welcome!
    Have you scrolled through the baquacil forum? You'll note a strong bias towards conversion and not much for use. Apparently the chemicals are pricey and after a few years people start suffering from weird sheets of mold and so on.
    A well balanced chlorine pool (SWG is a chlorine pool, it's just made on site rather than dumped in) actually has less available, active chlorine than tap water. And many people report the salt is soothing to the skin.
    Try using the search function for exzcema and borates and read others' experiences.
    Re: SWG or Baquacil
    I try so hard not to be cynical, but the only reason I can think of to rave about Baquacil is if you are the person selling it. They make a lot more money off of a Baquacil user than they do off of a SWG user, which is hardly an advantage for you. The only possible reason to use Baquacil is if someone in your family has a true chlorine allergy (which is exceedingly rare).
    Sep 2009
    Tucson AZ
    121
    Re: SWG or Baquacil
    I'm not familiar with Baquacil but I can tell you that about 5 years ago I installed a Jandy Aquapure SWG system and it's been great. Very low maintenance and pretty reliable. Water feels great on your skin, no chlorine smell at all. Have not had a significant problem with corrosion although I did replace the in-floor cleaning system pump recently, but it was 9 years old anyway. If you do go with an SWG, I would highly recommend that you get one that reverses polarity on the cell regularly (Aquapure does that). It cuts way down on calcium build up on the cell.
    16,000 gal in-ground Pebble-tec pool / Pebble-sheen spa. Jandy AquaPure 1400 SW Cl gen (SWG) system. In-floor cleaning system w/ Hayward EcoStar 2.0 HP VSP pump. Hayward 31" sand filter. 900 sq ft Heliocol solar panels (on roof) w/ separate 1 HP Pentair WhisperFlow single speed pump. Water feature with separate Hayward 0.85 HP VSP pump.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SWG or Baquacil
    Read some of the baqucil threads and see if you still want to use it. Awful stuff.
    Essential Links:
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: SWG or Baquacil
    My daughter has eczema and I had to take her out of lessons at the local pool cause it's murder on her skin. Read my signature. Her skin will be soft as silk all summer. I will PM you later when I have more time. DON'T GO BAQUACIL!!
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: SWG or Baquacil
    Sister-in-law was was thought to have an "chlorine allergy" and has very sensitive skin. This caused my in-laws to use Baqua for almost 20 years. No way they would ever go back. Thousands of dollars tossed for dirty subpar water. She now often uses the pool with no issues.
    Go SWG.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: SWG or Baquacil
    Another option would be to go traditional BBB, meaning manually dosing your pool daily with liquid chlorine. You can add salt to the pool at the levels you would for a SWG for the salt feel. You can add borates to. You could run the pool like this for awhile, if you encounter no skin issues than you can easily install a SWG to avoid manual dosing of chlorine. If you encounter skin issues and think Bagua would be better you could just switch then (might want to research salt levels with baqua).
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2013
    Michigan
    2
    Re: SWG or Baquacil
    Thank you for all of the replies. I did browse through the baquacil posts here and it pretty much confirmed everything else I've read. We are going with the SWG, so I'm sure I'll be back with more questions. I looked up the pool warranty online and it doesn't say that using one will void the warranty (as the pool store owner stated). It just says that the warranty doesn't cover any damages caused by using a SWG. I wouldn't expect it to.
