Thread: lowering TA
    lowering TA
    I just converted to swg pool. Chlorine is great however my TA is 110 (s/b 60-80) and my pH is 7.2. Should I lower my pH below 7.0 and then us air to raise pH back up or will lowering to 7.0 be enough?
    21000 gal
    vinyl
    21000 gal vinyl lined in ground
    36 sq. ft. DE filter with Hayward 1.5hp VSP
    SWG chlorine
    Massachusetts
    38,272
    Re: lowering TA
    You should only lower the pH down to 7.0-7.2 and then aerate to raise it back up.
    Re: lowering TA
    ok. so lower it then raise it and repeat until the ta is correct?
    SWG chlorine
    Massachusetts
    38,272
    Re: lowering TA
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Re: lowering TA
    You can just wait and the pH will rise on its own as the TA is high. Once you are not adding CYA just let the SWG run and pH will drift up on its own.
