Thread: What to adjust first?
    First...so glad I found this forum. I am on year 2 of Intex Easyset 15'x48". Started SWG and larger pump this year. learning BBB for this pool before putting in the inground next year. So here goes: FC 0.5, pH 7.8, TA 100, CH 50, CYA 40. Want to add bleach to raise FC and a small amount of Muriatic acid to lower pH a little. Which should I do first and can I do them one after other or wait in between.
    2012 Intex Easy set 15x48/Krystal Clear 635T pump/CS8110 SWG
    22,543
    Re: What to adjust first?
    Welcome to TFP.
    I'd add the bleach first, wait 30 minutes and then add the MA, wait 30 minutes and retest the pH and FC. If it's where you want it, go swimming.
    Thank you! I will do that this evening.
