Thread: Pump Help
    Pump Help
    Any ideas what might be wrong with my pump? It's a Jandy Stealth with a 2HP A.O. Smith motor on it. It's about 9 years old. Pool is a 14k gallon pool with a cartridge filter. The pump makes a buzzing noise and won't turn. I'm think it may have overheated as it is over 100 degrees and the pump housing burns to the touch. Need a short term quick fix while I figure out what pump I should replace it with. Would also like some ideas on a replacement as well. Was looking at the variable pumps like the pentair and such but really on the fence at this point on the pumps. Thanks in advance for any suggestions....
    16K Freeform Gunite with attached spa; Pentair Intelliflow VS; Pentair Mastertemp heater, Intellichlor, Pentair FNSP60 DE Filter.
    22,553
    Re: Pump Help
    Have you taken the back cover off it to see if you can turn it by hand? If not I suggest you do that first.
    If it will turn then it's most likely the start capacitor. They're eaasily replaced. The pool store might even have one.
